From lift to stock? - Defender Source
Old February 20th, 2013, 11:22 PM
Gordonhurst
Mark
From lift to stock?
Can anyone give me a sense of roughly how much would it cost to convert a NAS D90 with a 2 inch lift back to stock springs/shocks (parts and labor all in)?
Old February 20th, 2013, 11:26 PM
That is a hard question. You could get stock used parts basically free and I would say two hours labour to swap.
Old February 20th, 2013, 11:27 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Takes a couple hours of labor, plus a set of stock springs. You can probably reuse the shocks, depending on what kind they are. It's not a big deal at all. You can do it in the garage with some jack stands and a floor jack, but it's easier on a shop lift.
Old February 20th, 2013, 11:38 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
It's a fairly easy job... Floor jack spring compressor (you can rent them) and probably about 30 min - 1 hour per corner if doing it first time.
Easier for the rear, a bit more involved in the front. Springs and shocks can be sourced free or swap your lift to someone with stock suspension wanting to lift their truck.
Let me know if you need help, I'm in north jersey as well as some other folks in he forum.
Glenn
Old February 21st, 2013, 08:10 AM
2" is a popular lift, so factor in that you'll likely be ale to sell the springs that are on there currently if they're something popular like OME 762 or around that range.
Actual lift measurement with OME KevinNY Defender Technical Discussions 1 February 2nd, 2006 04:18 PM
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Stock diff, stock rear axle half shafts..... nilesj For Sale - Parts 5 October 15th, 2004 11:10 AM
Inexpensive, minor lift ideas sought.. LRNAD90 Defender Technical Discussions 1 September 16th, 2004 06:59 PM
Stock 90 Parts for Sale Joe B For Sale - Parts 2 October 15th, 2003 11:57 AM
