Friday Ramblings.. - Defender Source
Old February 19th, 2016, 08:13 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Friday Ramblings..
You know, I was under the truck the other day thinking..
It is too bad the frames are made with so many holes in them. Invariably they just allow the frame to fill up with mud, sand, salt and other crap that leads to rust out.
What if the frames where made so that they were sealed end to end (permanent cross-members included)? Just think, we could use them as big air tanks for our onboard air systems. No nasty stuff would get inside (okay, you'd need to put an air dryer on the compressor or you'd be filling the frame with moisture all the time, but otherwise). Alas, its all about the money, and I'm sure it would be very time intensive (therefore EXPENSIVE) to produce a frame in this manner..
Like I said, Friday Ramblings..
TGIF Everyone!
~Scott T.
'95 D-90 ST - AA Yellow
Old February 19th, 2016, 08:29 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Using the frame as an air tank would eventually lead to corrosion...
But... how about just a big, strong C-frame like my Excursion and every F-250/F-350 of that generation had??
Nowhere for mud and debris to hide.
Rent my
Old February 19th, 2016, 09:18 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Bad idea jeans.
You need a box frame for rigidity to make the bolt together rover body work. Otherwise the doors would pop open from crossaxleing a speed bump.
-Jeff
use thickerer metal
or better engineeerin'
The Rover looks like everything is built as an afterthought
oh, you should see the way my *rigid* box frame flexes
Rent my
Old February 19th, 2016, 09:49 AM
TGIF Everyone!
I think galvanizing the frame and separate air tanks is the was to go ... although in your example it mights be OK as a diesel tank ... ;-)
Old February 19th, 2016, 11:24 AM
Holes in frames are like gaskets. Designed weak spots to allow the oil to leak out.
Old February 19th, 2016, 11:26 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
-Jeff
My doors open when driving on flat ground, I imagine the flex of a C-frame would force the doors to stay closed!
I think a galvy C frame boxed in strategic spots would be awesome, as you can still clean the inside of it.
Old February 19th, 2016, 07:26 PM
use thickerer metal
the only thing rover got right was the LT230 and the parking brake.
Old February 19th, 2016, 08:11 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
What about putting more holes and dimple die them ? Especially the outriggers. And then galvanize it?
Black Friday Special - Stainless steel door panels LenB For Sale - Parts 18 December 23rd, 2006 11:56 AM
Friday Night Video's norros Misc. Chit-Chat 0 January 7th, 2005 10:52 AM
Ramblings evilfij Misc. Chit-Chat 5 May 6th, 2004 09:34 AM
here is a fun one for friday afternoon read Misc. Chit-Chat 0 April 30th, 2004 08:31 PM
Where to go in CO on Friday nickt Misc. Chit-Chat 1 April 21st, 2004 02:01 PM
