Frame is solid means what? - Defender Source
Old October 29th, 2011, 01:33 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
Seller states "frame is solid". This is a term used frequently but tends to be a matter of opinion.
How do you define it?
Patches are for Pirates and pants, not a bulkhead and chassis!
Old October 29th, 2011, 01:37 PM
Not rusty enough to poke a screwdriver through.
------ Follow up post added October 29th, 2011 01:39 PM ------
If I was going to buy a truck that had a frame that looks like the one in the picture, I'd pretty much plan on a new frame.
Old October 29th, 2011, 01:40 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
That looks like a new rear cross member was welded on with extensions. It also appears as though there is some rust bubbles sprayed over with waxyol.
If you can I would get under it and tap the frame with a hammer in various spots to look for soft spots.
Old October 29th, 2011, 01:46 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
That'd be my definition too, although it still leaves a lot interpretation, ie patches, bondo, etc
Semper Fi!
Old October 30th, 2011, 11:43 PM
carlosz's Avatar
carlosz
Carlos
if someone told me a frame "is solid" I wouls expect to hammer trouble known spots and feel or hear a very solid thud or ping in return.
no chipping or peeling observed no paint overs to cover spots and normal surface rust shall be expected as well.
Old October 31st, 2011, 07:10 PM
Ask to see more detail to the right of that area
Originally Posted by pendy
I'm here for the D's
Old October 31st, 2011, 10:07 PM
draaronr's Avatar
draaronr
Here
LR3
you ask and you shall receive, yes po put on a new rear cross member so obviously the old one was shit, and here is a few more pics, old original frame but far from needing a swap as Bill suspects. found one patch on an outrigger but other than that nothing visible, asking price is in the 12s for a 200tdi with and lt77.
ID:	43301   Click image for larger version
ID:	43303   Click image for larger version
ID:	43305   Click image for larger version
Old November 1st, 2011, 10:39 AM
carlosz's Avatar
carlosz
Carlos
new rear xmember a decent done job (not a hack saw and patch). rest of frame seems to be a decent eye pleaser as well.
Old November 1st, 2011, 11:51 AM
broadstone's Avatar
broadstone
I was simply interested in others opinions of what this term could mean as it is used all the time and thought the photo could be used as an example. I classify a frame as new, or original (unwelded), or repaired. I personally would not refer to a crossmember replacement installed in that fashion with welds that looked like that as solid. In my line of work a weld must pass an inspectors visual test before they will even test it structurally. The rest of the frame however does look pretty good.
How straight is a typical Defender frame? madcowdungbeetle Defender Technical Discussions 9 August 22nd, 2009 05:43 PM
Rear A-Arm Frame Brackets..etc TDI Guy Wanted 14 February 16th, 2006 09:15 AM
109 Galvanized Frame Coiler For Sale - Parts 1 December 29th, 2005 11:53 PM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
looking for seat frame jcasteel Wanted 0 July 19th, 2005 09:55 AM
