? For those who have gaLvanized stuff - Defender Source
Old October 22nd, 2011, 02:29 PM
JBinAlabama
john
Series 2A ..more parts on the way
Question ? For those who have gaLvanized stuff
I'm ALMOST ready to drop a load at the galvanizer! What should I do with the threaded parts? I've seen mention of high temp silicone but need some advice. This is a series 2a 88 and I'm doing the frame, bulkhead and pretty much every other steel part and bracket. DANG there are a lot of pieces
Just when I think I'm done, I find another part or assembly to take apart and add to the pile!
Also, on the smaller pieces, should I wire them together in groups?
Thanks for all the great advice on this project! We are having a blast!
Old October 22nd, 2011, 10:00 PM
61rover's Avatar
61rover
John Crouse
I don't recommend the plug with bolts method. I tried that on my B-pillars and still ended up breaking about 1/4 of them.
Old October 22nd, 2011, 11:31 PM
about to do a bulkhead, tposts, some door frames, sankey tub etc. I too would like to know what others have done
Old October 23rd, 2011, 12:05 AM
Tino.R's Avatar
Tino.R
Tino Rebelo
67/series IIA
doug i galvanized my bulkhead and lots of other part and i use high temp. gasket maker. cover the bolt with it thread thr bolt until the end is flush and rub some gasket maker to cover the end of the bolt.works great.
Old October 23rd, 2011, 01:57 AM
I just left all the holes open and re-tapped them after dipping. I did make a mistake and Galveston the screens though, and that made for a lot of work drilling them out...
Old October 23rd, 2011, 07:00 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
I also left the threads exposed and retapped. I think it is best. In the industry it is called nine wire that is used to wire parts together.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old October 23rd, 2011, 10:24 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
I would recommend double checking to make sure you haven't included any parts that aren't steel. The inside door pulls, or the small panel on the bulkhead where the choke cable comes thru for example. They wont survive the process. Post up some pics when you get things back!
Daniel
Old October 23rd, 2011, 01:25 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Me as well, when i got my chassis and B pillars (amongst other bits) dipped... i tried leaving some smaller bolts in place, and couldn't shift them when i got the parts back, so i just left the rest of the holes empty, re-drilled the correct size and re-tapped the threads.
There's quite a few on the B pillars on a 110 SW
Old October 23rd, 2011, 02:23 PM
JBinAlabama
john
Great advice guys! Anything else?
Old October 23rd, 2011, 09:16 PM
JBinAlabama
john
Based on previous suggestions I need some metric taps!
Do you guys by tools online or locally?
I live in a tourist town with the nearest Lowes 30 miles one way from my house.
If you have had succes with an online supplier who is it please?
Old October 24th, 2011, 02:51 PM
I have been very happy with my craftsman big metric tap and die set. Zinc is really easy to drill and tap as it is so soft.
Old October 24th, 2011, 03:39 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I covered the threads in red RTV before installing. They came right out no trouble at all.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old October 24th, 2011, 08:46 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Here is what I tried and the results
http://www.defendersource.com/forum/...t=26346&page=4
Old October 24th, 2011, 09:16 PM
JBinAlabama
john
Hey Dave,
I JUST found your thread about this! GREAT info there!
So just to be clear, you put the red RTV in the threads? like in the tube?
Also, are there any parts that you wish you had done while you were at it?
I keep looking at the drive shafts and wondering if they can be done.
Old October 24th, 2011, 09:28 PM
broadstone's Avatar
broadstone
Will most likley throw off propshaft balance, plus they do not tend to rot.
galvanizing, rebuild, series
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
Hard Top and Stuff ron For Sale - Parts 22 November 14th, 2004 06:35 PM
FS: Misc stuff: cubby/jack/tool roll NASD90 For Sale - Parts 1 October 19th, 2004 06:33 PM
painting galvanized stuff artm Defender Technical Discussions 5 June 29th, 2004 02:19 PM
Galvanized stock shock towers... dmarchand For Sale - Parts 1 May 22nd, 2004 04:28 PM
