Fluids for a LR3 - Defender Source
Old February 8th, 2014, 06:52 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Fluids for a LR3
What fluids are people using for the engine, transmission, t/c case, and diffs these days? I hope it is not some $33/qt dealer specific stuff I am reading over at LandRover.org
Old February 8th, 2014, 07:00 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Mobil 1 for the engine...but yes, the dealer specified stuff for the rest. Got it all to once and used a 15% off coupon fm AB to make it hurt a little less. Thankfully I don't see myself changing dif fluid nearly as often as in the D1.
Old February 8th, 2014, 07:08 PM
Grover's Avatar
Grover
Full synthetic Castrol for the engine, LR fluids for rad, tranny, tcase, and diffs...
Good times...
Old February 8th, 2014, 07:23 PM
down_shift's Avatar
down_shift
Russell
Recommended frequency for all?
Old February 8th, 2014, 08:12 PM
Ray_G's Avatar
Ray_G
Ray Gerber
After you establish a baseline (unless previous history is a documented known) this is what I am going to operate off:
http://www.disco3.co.uk/gallery/albu...0-%20miles.pdf
Old February 8th, 2014, 08:16 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I use Castrol Syntec in the engine... then LR Factory unicorn blood in the rear locking diff. Other stuff just meets specs, it's not "land rover green label".
Old February 8th, 2014, 10:06 PM
Castrol synthetic 5w30 in the engine every 5K, trans/tcase/diffs yes as mentioned it generally is the Rover specific fluid....which is pricey. But considering I have to flush my diffs and refill the tcase in the 90 with a frequency that seems to be every time I go wheeling it's probably ultimately cheaper to do the LR3 service at $30/qt and leave it in there for the 60K duration!
Now all that said, to be frank the dealers actually now use the BG fluids for the "regular" diffs (i.e. not the electronic locking rear diff). The fluid for the regular diffs is BG752. The electronic locking rear diff is the only one that still requires the Rover fluid - which is LRN500070.
The transfer case & gearbox I *believe* were spec'd out at the dealer (again, last I checked) as the BG753 fluid as well (versus the Rover specific fluid).
------ Follow up post added February 8th, 2014 10:14 PM ------
Russell, you may also find my prior rant found here useful:
http://www.defendersource.com/forum/...9&postcount=26
Old February 8th, 2014, 10:25 PM
down_shift's Avatar
down_shift
Russell
All great info, thanks.
At 5000 miles between oil changes, is it typical to see any oil consumption? If so, how much?
Old February 8th, 2014, 10:28 PM
Zero consumption, probably even past 5K. This isn't a Series truck . And I mean zero...at 100K+ it doesn't move off the dipstick mark on mine.
And probably most will tell you that a 5K oil change with synthetic is ludicrous, but it's how I was raised and so far it's worked for me and the hundreds of thousands of miles I've put on a plethora of vehicles. But I've always done oil changes at 3K dino & 5K synthetic, and I sleep better at night because of it.
OR, you could just be like that other dude on here (don't recall exactly who it was) that went 44K with only 1 oil change on an LR3 and told me I was the idiot for changing at 5K.
Old February 8th, 2014, 11:04 PM
I've got a bunch of the transfer box fluid if you guys need any.
Old February 8th, 2014, 11:47 PM
jafir's Avatar
jafir
Jafir Elkurd
I'd be interested!
Old February 8th, 2014, 11:58 PM
Grover's Avatar
Grover
Use the K&N oil filter. It's so much easier to remove with the wrench flats. There is very little room to get a strap wrench oil the filter.
Happy motoring!
Old February 9th, 2014, 01:48 AM
navydevildoc
Neill Thornton
I haven't seen a drop of oil burn on mine, and I just rolled past 160,000 miles.
I usually change somewhere between 5 and 7.5 k... it's a pretty penny on that oil change when you are filling it with Syntec.
Old February 9th, 2014, 02:47 AM
I have the same/similar motor (but supercharged) in the jag and it burns no oil at all and I run 5w30 synthetic.
Old February 9th, 2014, 10:19 AM
Originally Posted by jafir View Post
I'd be interested!
Can I ship transfer box fluid? I saw most of the other guys are close to me. I don't know about the rules of shipping oils, and they usually leak when they are shipped to the dealership.
Old February 9th, 2014, 10:29 AM
whats so special about the transfer case? surely redline amsoil castrol etc have a fluid that will meet the spec?
Old February 9th, 2014, 10:43 AM
jafir's Avatar
jafir
Jafir Elkurd
I don't know for sure. When I worked in a garage years ago, I'd order parts from worldpac, almost everything came DHL overnight, but fluids had to come UPS ground.
------ Follow up post added February 9th, 2014 09:44 AM ------
It's got an infinitely variable diff lock, like the HD rear axles, and I guess if you don't have to correct friction modified fluids, it will be locked up at times when is shouldn't be fully locked.
Old February 9th, 2014, 01:05 PM
I've definitely fixed trucks that have come from independent shops who put the wrong oil in them. The transfer case locks up when it should be unlocked. I'm sure you could add some limited slip lubricant or something to them, but I would just stick to the factory lubricant.
Old February 9th, 2014, 02:45 PM
down_shift's Avatar
down_shift
Russell
Jimmy, using Ray's link to the factory LR3 maintenance checklist, the schedule to renew the engine oil/filter is every 7.5k or 6 months, slushbox oil/filter every 150k or 10 yrs, transfer box every 75k, f/r diffs every 10 yrs (every 75k for the r locker). Do you see any reason to accelerate this schedule in one area or another? Else, I'll just follow this and save the $$.
Old February 9th, 2014, 02:52 PM
Grover's Avatar
Grover
The diffs do not hold much oil. It's best to change more frequently than 75k
There is lots of talk about the diffs on other forums. Some say to change the fluid once a year.
It's all easy to change but the trans. Save $$$ and change the fluids yourself.
Welcome to the modern rover...lol
LR3 Navigation system blenkush Defender Technical Discussions 1 March 24th, 2006 01:31 PM
New LR3 model Willh Misc. Chit-Chat 14 April 25th, 2005 02:00 PM
Lr3 rover4x4 Misc. Chit-Chat 12 January 17th, 2005 10:58 AM
Lr3 mhansen Misc. Chit-Chat 24 April 26th, 2004 11:00 AM
LR3 Unveiling...in NYC dmarchand Trips, Trails and Events 3 March 29th, 2004 01:44 PM
