flip up head unit - Defender Source
Old June 25th, 2010, 06:04 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
flip up head unit
Is anyone running a flip up head unit in there center console? If so which one, and do yo uhave any pictures of it installed? Pros/cons of this set up?
------ Follow up post added June 25th, 2010 06:27 PM ------
Also, the reason I am thinking about this is to use it as navigation. Are there any suggestion for units with good on/off road navigation programs?
That is why it is called a short cut. If it was easy it would just be "the way."
Old June 25th, 2010, 10:08 PM
If the radio is in the stock location, I think the screen could get in the way. Not to mention that the navigation function might be difficult to use.
But, try it, be a trendsetter.
Old June 25th, 2010, 11:45 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Not done it myself but these pics would suggest that it would be hard to see and might get in the way of the shifter (If you wanted to shift into 1st like when using engine breaking in hilll descents)? If you are driving and trying to use it as a GPS I would imagine it would be a PITA as well as dangerous to keep looking down there. If it was a motorized screen then I am not sure the mechanism would last overly long either.
Just my 02c.
Pics are borrowed from an eBay listing.
ID:	28838   Click image for larger version
Old June 26th, 2010, 10:20 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
what kind of console are you running? if you are running a Tuffy box then I would assume the lip around the stereo mount would be too much unless you raise the radio up with a spacer of some kind and then you would still probably need to make sure the unit has multiple angles. I thought about doing this in my truck as well for navigation as well because I am tired of picking the suction cup mount up off the floor!
Old June 26th, 2010, 10:26 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
It is a tuffy, and I think I am leaning away from this idea. I just don't think the motorized screen would last long driving off road. I live about 10 miles down a dirt road that is not maintained, and it is hard an everything. I guess I will just have to go with a separate gps. Thank you all for your input.
Old June 27th, 2010, 12:19 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Len from American Dirt Roads built me a custom mount for my Garmin GPS. It sits on the dash above where the ashtray used to sit. This installed without drilling a single hole. I ran power up through the dash so it's mostly seamless. It also has a mount for the head unit of my Kenwood TM-D710A radio.
Pics here:
http://www.flickr.com/photos/defende...7606694461778/
I'm removing it soon and going a different route on the radio and GPS. Going to build a new GPS mount that sits on the far left side (also drill-less) and will be mounting an Icom radio faceplate down to the left of the hazard lamp switch (again, no drilling).
Old June 27th, 2010, 08:07 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
that looks good. I am thinking of something that isn't so easily seen from outside the truck.
Help with factory head unit WCURoverD90 Defender Technical Discussions 27 October 21st, 2006 06:54 PM
97 Stereo Head Unit gtg067i Wanted 3 July 8th, 2006 05:16 PM
Looking for a 97 D-90 Stock Radio / Head Unit amasaback Wanted 0 November 11th, 2005 08:40 PM
Looking for OEM Head unit Eric Siepmann Wanted 4 October 26th, 2005 11:50 AM
