Finally have a roof - Defender Source
Old October 25th, 2003, 01:59 AM
Finally have a roof
Got the fiberglass hardtop on
It is so nice to have heat but it is so weird driving with a roof. Its quiet, crap does not fly out of the back.
Man if it had room in it for my left arm it would just be like the disco.
Anyway I was just posting to say that it is way better than a soft top for noise and weatherproofness. It is a complete crap design but it does its job.
Ron
Old October 25th, 2003, 10:40 AM
Did you order a number of these a while back that came in damaged? Do you have any that might take some work to get back together (even a lot of fiberglass work)? I'm not concerned with keeping the original finish, but rather filling in the texture and painting the whole thing black. So I'm looking for a damaged but fixable top to work with.
BTW - are the windows in the HT glass or plexi?
Old October 26th, 2003, 11:30 PM
I have one busted side if it will help (not likely). Other than that everything I have is on the truck, chris cox has a busted roof.
windows are glass.
Ron
Old October 27th, 2003, 10:59 AM
mgrgpg
Mark
1989 D110
How are your window seals...siliconed my top in all the right places, and it is leak proof....the only spot I seem to get water in is where the windows meet the seals.
I just put in a new set of door seals, and still get a puddle inside. I have not determined if it is coming through the seal area or actually running under the window and through the bolt holes the hold the windows in place.
Mark
Old October 28th, 2003, 09:13 AM
Eric_S
Eric
'97 D-90 ST #1507
FWIW-
The first year that I put my fiberglass top on my self I went around and put silicone sealer on all the bolts and square washers along the top to stop leaks. The good news is that it worked really well but the bad news is that it was a PITA to get the bolts off in the spring. I had to go around with a razor and cut away the silicon. Now I use what's called "cord weather-stripping" (you can find it on most hardware web-sites).
http://builders-hardware.aubuchonhar...rip-271225.asp
I just put a little ribbon under the washers and tighten away. Not only does it stop the leaks it has an added benefit of letting you know how much to tighten the bolt, i.e. once it starts to squeeze out that's usually tight enough. I also use it seal the gaps around the roll bars.
Hope this helps out
Eric
roof
ST roof rack mounting question Matt Taylor Defender Technical Discussions 8 March 9th, 2006 03:45 PM
Hard case roof tents D90user Misc. Chit-Chat 1 February 16th, 2006 11:53 AM
ISO: ANY PARTS for NAS safety devices roof rack NASD90 Wanted 3 February 28th, 2005 01:22 PM
Humor the ST aluminum roof dream... thecatsmeow Defender Technical Discussions 30 October 5th, 2004 08:31 PM
No roof! jamesmorfee Defender Technical Discussions 3 March 5th, 2004 09:24 AM
