favorite rust converter? - Defender Source
Old March 10th, 2014, 01:34 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
what is your favorite rust converter?
I have used many different brands, both brush one and rattle can, and some work much better than others - so I just wanted to see your thoughts.
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old March 10th, 2014, 01:38 PM
All "rust converter" is phosphoric acid. This changes the rust in ferric phosphate. A can of coke works fine... Or go to the hardware store in the concrete cleaners: http://www.homedepot.com/p/Miracle-S...-100672863-_-x
If you want to "get rid of" instead of convert the rust, Muriatic (hydrochloric) acid is the normal choice, also in the concrete cleaners at the hardware store.
Old March 10th, 2014, 01:42 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Is that safe on paint?
Old March 10th, 2014, 01:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
I find pissing on the rusty metal does the best job converting the rust to fresh steel again. If that doesn't work I use some easton crap.
Old March 10th, 2014, 01:56 PM
Permatex is the only one worth using
Old March 10th, 2014, 02:02 PM
Old March 12th, 2014, 12:54 PM
Stilts
Y Ammann
110 def ex ffr 2.5na
ive used "penetrol" made by flood to treat rust before final coats. i brush penetrol coats on rusty metal until it gets a wet look (glossyish) when dry. then mix penetrol and paint (do a small test before to make shure both mix well together) and then 1-2 coats of paint alone.
my2cnts
Old March 12th, 2014, 03:22 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Por-15.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old March 12th, 2014, 03:26 PM
POR-15 does not convert rust. It covers it up. They sell a rust converter, which is phosphoric acid....
Old March 13th, 2014, 05:33 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yet another alternative.
http://youtu.be/vq5IUiYMhRM
And obligatory Land Rover content
http://youtu.be/0L-AYdXq-OE
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 13th, 2014, 05:44 AM
Kleen strip prep and etch / phosphoric acid works best for me.
Torque Converter re-Install trouble Michael Defender Technical Discussions 3 November 6th, 2005 09:18 PM
Rust Question Rob Defender Technical Discussions 0 August 29th, 2004 01:40 PM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
