Fasteners for LaSalle Headliner??? - Defender Source
Join the Defender Source Community Today
Old July 31st, 2016, 10:58 AM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
All - I bought the pictured fasteners from RN for my LaSalle Headliner however they sheer off when hammered in.
Should I be using the push pin kind? If, so can you point me to correct brand and size?
Thanks!
Old July 31st, 2016, 11:29 AM
Those pins look like they should be pushed in not hammered.
Old July 31st, 2016, 12:08 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Victor,
The christmas tree type fasteners are not ones we suggest for the Lasalle headliners. We are the only authorized reseller for Lasalle and have put in a lot of headliners...
There are two methods we like to use for headliner retention, depending on your use and plans.
My favorite is to use a standard pop rivet for the least amount of headliner movement once installed. There is a specific sequence to the riveting in order to have the best fit.
Alternately the Lasalle headliners come with pushbutton type poly rivets - these work well if you plan to remove the headliner or are not anticipating hard use.
Old July 31st, 2016, 12:59 PM
ATX_D110's Avatar
ATX_D110
Victor
Originally Posted by Mybluett View Post
Victor, The christmas tree type fasteners are not ones we suggest for the Lasalle headliners. We are the only authorized reseller for Lasalle and have put in a lot of headliners... There are two methods we like to use for headliner retention, depending on your use and plans. My favorite is to use a standard pop rivet for the least amount of headliner movement once installed. There is a specific sequence to the riveting in order to have the best fit. Alternately the Lasalle headliners come with pushbutton type poly rivets - these work well if you plan to remove the headliner or are not anticipating hard use.
Thank you - I picked up some of the pictured and all is coming together!!!
ID:	154866   Click image for larger version
Old July 31st, 2016, 08:46 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
push those in. For the tough ones, rubber mallet with a clean rag between the two.
Old October 28th, 2016, 08:04 AM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
I ordered a LaSalle headliner for my 110. I bought 4 speaker pods as well. Will the speaker pods get in the way of an 8 point SD roll cage install?
Anything else I should know with this install? LaSalle recommended using screws instead of the plastic fasteners so we could remove it later on
Old October 28th, 2016, 08:11 AM
ATX_D110's Avatar
ATX_D110
Victor
Originally Posted by jason1st View Post
I ordered a LaSalle headliner for my 110. I bought 4 speaker pods as well. Will the speaker pods get in the way of an 8 point SD roll cage install? Anything else I should know with this install? LaSalle recommended using screws instead of the plastic fasteners so we could remove it later on
Pretty straight forward on the install - I suggest having an extra set of hands and don't be surprised if you need to tap a few new holes.
As for fasteners, I used these from Home Depot and they are holding tight thus far.
Can't comment on the speaker Pods but if they don't work out, let me know
Old October 28th, 2016, 08:32 AM
jason1st
Jason Crandall
Thanks for the info....
Also, the headliner I ordered needs to have the Alpine Windows cut out. He sent trim pieces that fit into the holes after they're cut. Did you have to do this? He recommended mine be done this way because my body shop custom cut the Alpine Windows into my Puma roof and they could be off from factory a little bit.
Does your roll cage not have any internal hoop?
LaSalle headliner Roverlab Wanted 2 March 13th, 2015 12:26 PM
LaSalle trim headliner install usadventureracing Defender Technical Discussions 25 October 16th, 2012 07:21 AM
LaSalle Headliner Question Stmpede Misc. Chit-Chat 4 March 28th, 2011 12:46 PM
How thick is a LaSalle headliner? Need for roll bar install peachyracer Defender Technical Discussions 24 June 11th, 2008 02:21 PM
How to ship lasalle headliner and SW trim panels? Chris Cox Defender Technical Discussions 4 March 23rd, 2005 07:07 AM
