fabricators, which plasma cutter? - Defender Source
Old January 14th, 2016, 09:47 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
with the addition of a new welder, i'm looking to get a new plasma cutter. So:
which ones are you guys using?
do you like it?
do you wish you had another cutter?
Old January 14th, 2016, 09:51 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Hands down hypertherm
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old January 14th, 2016, 10:09 AM
I feel like I have an opinion on everything nowadays and I hate myself for it.
At the risk of propounding idiocy, I'll say this:
The model of any tool makes no difference in this declining order: Plasma cutter, TIG welder, MIG welder
In the Plasma Cutter's case, the model is almost totally irrelevant. The Plasma Cutter just provides an air inlet via solenoid, an HF igniter, and then a constant current source. This is done by almost every plasma cutter on the market down to the most take-out chinese-y variant every made.
Therefore, the only thing that differs between models is the torch itself. The torch itself, its consumables, and its internal design, are the only things that differ.
The main models that I have seen are:
1. Trafimet torches
2. Nutec
3. Binzel
4. ESAB / China long-biznizzle (not the real name, just used to denote long electrodes)
5. ESAB / China short-biznizzle (not the real name, just used to denote short electrodes)
Then the individual "big name" manufacturers have custom made torches with custom made consumables, which are designed to lock you into their expensive pricing schemes.
And yes, you can use an expensive-a$$ torch on a cheap-a$$ power supply.
I believe hypertherm uses China biznizzle torches, although they are some kind of funky ISO design. Again, even a poor man's plasma is almost identical to a rich man's plasma. So buy whatever is in your budget and just cut stuff and enjoy.
Old January 14th, 2016, 10:15 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I went for Hypertherm and really like it. Consumables can be purchased at most any respectable welding shop. Once you settle on the capacity of machine you want, I would suggest you buy the next bigger one.
Old January 14th, 2016, 10:19 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
What are you are cutting, what kind of air source and do you have a 220 power source?
bossman429's Avatar
bossman429
Adrian
1988 90
I have a hyperthermia 35. It's a beast of a little machine.
Old January 14th, 2016, 10:43 AM
ezzzzzzz
Mark Garrenton
I run Miller products, mig, tig and plasma. They're the primary equipment used at my govt shipyard employment. Costs to get into these isn't horrible considering the long term investment aspect. I've certainly gotten my money's worth out of it all.
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old January 14th, 2016, 11:00 AM
oilburner's Avatar
oilburner
JL
large pile of parts
What are you planning on doing with it? General 4x4 stuff or are you starting a shipyard? For 4x4 stuff I would way Hypertherm Powermax 30 is your best bet.
JL
Old January 14th, 2016, 12:02 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
One of the biggest problem I've seen with home plasma cutters is not enough voltage for consistent clean cuts and bad air…low PSI, low air volume and wet air will destroy the cutter and leads to poor cutting.
Miller Extreme 375 ran at 220 is plenty of machine for home use. Needs 90psi and a compressor that can maintain a healthy volume air. I use a Ingersol single stage 60gal compressor, and that's barely enough.
Old January 14th, 2016, 12:27 PM
I used to have a Parker Plasma cutter that I bought when they were selling them on Pirate for like $300. I had zero complaints with it. Worked every time and the cuts were always good as long as the tip was in good shape. I have a 60 gal Ingersol Rand compressor.
Old January 14th, 2016, 12:35 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I've been using a Miller Spectrum 375 Extreme for 10 years now. No complaints, other than it's best suited for 3/8" and smaller metals. It'll do thicker, but requires multiple passes.
It's dual voltage, but I rarely use it on 110v.
Semper Fi!
Old January 19th, 2016, 01:27 PM
rankar's Avatar
rankar
Thanks guys, lots to consider. I don't see myself cutting anything thicker than 1/4.
Seems like the usual suspects.
Old January 19th, 2016, 02:37 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Something to keep in mind. Many of us that use plasma cutters also have a horizontal band saw like you can get at Harbor Freight. Way more useful for the most part, great cuts, easy to set up. Often times people are totally enamored with a Plasma just to find out they rarely use it.
It really depends on what you want to cut. If it is straight metal like tubing, I would rather have a band saw, at least have it first...
Old January 19th, 2016, 03:24 PM
Contractor's Avatar
Contractor
Will
1969 IIA
I have a Thermal Dynamics Cutmaster 42.
I have not had it long, but it's a great machine.......will cut up to 1/2". I run it on 220V, but it will run 110 just fine as well. Make sure that if you are using the correct consumables with whichever power source you decide on.
Anyway, the TD machines are really nice and are what a lot of good fabricators in my area use.
Thermal Dynamics FP20a Plasma Cutter giftshopduane The Flea Market 0 September 5th, 2012 09:51 AM
plasma cutter, dirtbike killahaas The Flea Market 2 August 31st, 2012 03:02 PM
Need a new quality Tubing cutter Chris Velardi Defender Technical Discussions 8 August 8th, 2011 10:40 AM
Roll cage fabricators in NY/NJ area? Naplm00 Defender Technical Discussions 27 January 26th, 2011 11:10 PM
Plasma cutter recommendations Chris Velardi Defender Technical Discussions 14 June 14th, 2010 04:50 PM
» Defender Registry
1989 d90
1355sock
D90
NPT90
Add your Defender
