Fabrication Question: Brackets - Defender Source
Old March 16th, 2015, 12:28 PM
BlackField's Avatar
BlackField
Oscar
D110
Hello all,
I need a few random brackets for some stuff I want to attach to my 110. I have a sheet metal brake, a press, a couple of dimple dies and a nibbler. I want to know what the name of the die or tool is that makes this reinforcement notch in these 90 degree brackets. I have an idea of what it could look like but haven't been able to find the tool itself online.
Old March 16th, 2015, 01:00 PM
side question but what part of the body are you trying to attach it to and what are you attaching with these brackets?
Mark Kellgren
KM4BOR
Old March 16th, 2015, 01:50 PM
BlackField's Avatar
BlackField
Oscar
D110
I have a small heater core/ fan combo that is going to go above the right rear wheel well tucked close to the tub side. Its likely not a necessity to have the reinforcement "notch" or whatever it's called but I have at least three other brackets to do and figured why not start with this one.
Old March 16th, 2015, 02:15 PM
I'm no help on the proper tool, but if I had to do that, I'd cut a notch out of the side of my vise anvil, and smack that bracket with a blunt chisel in the notch.
Mark Kellgren
KM4BOR
Old March 16th, 2015, 02:34 PM
Just make the brackets from angle stock.
Old March 16th, 2015, 02:41 PM
BlackField's Avatar
BlackField
Oscar
D110
I want to make the brackets from sheet metal since I can form the brackets into more complex shapes than I could with angle iron. I also don't have a welder at the moment.
Old March 16th, 2015, 03:04 PM
Plus angle stock looks like poo
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old March 16th, 2015, 03:14 PM
BlackField's Avatar
BlackField
Oscar
D110
There's that too.
Oh well instead of working I've been google'ing. They are called darts or gussets.
one step closer.
Old March 16th, 2015, 03:19 PM
Not if you throw enough love on it. Little taper here, little radius there...
Old March 16th, 2015, 03:23 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
couldn't your local weld shop tack on a bit of metal to your brackets before you coat them?
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
those brackets are press formed and requires some serious equipment and software to produce
i'm sure you would be able to come up with something but it wouldn't be worth the time
SheetMetal.Me – Sheet Metal Gusset
No Mall crawler here
Old March 16th, 2015, 03:44 PM
BlackField's Avatar
BlackField
Oscar
D110
I just read the sheet metal me article a few minutes ago. Seems like there are more articles on how to make a gusset on CAD than on metal.
I was hoping it would be two blocks of steel with a v mating surface and a captive punch I could just whack with a hammer and be done with it. If someone wants to make one I'll give you $49.95.
Old March 16th, 2015, 04:27 PM
Give George's friends a call
Mark Kellgren
KM4BOR
Old March 16th, 2015, 05:08 PM
BlackField's Avatar
BlackField
Oscar
D110
Haha
ac, bracket, rack
Slick Rock Fabrication Kick Panel Mike M The Vendors Loft 9 August 24th, 2006 06:05 PM
Cage Fabrication Jase Defender Technical Discussions 21 March 10th, 2006 10:31 PM
Fabrication stuff sale JBurt Misc. Chit-Chat 1 May 13th, 2005 02:56 PM
FAST BACK Bows and fabrication paulb Defender Technical Discussions 0 March 23rd, 2005 04:02 PM
Limb Riser Fabrication Peter Defender Technical Discussions 2 October 21st, 2003 10:34 PM
