Everybody should check this out - Defender Source
Old April 27th, 2004, 03:49 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Sorry for the attention getter....but,
Okay, I have been thinking alot about this and I think that it might be time to test the waters. Like I mentioned earlier, I have a 1.4 to 1 high range rover t-case. This is identical to the NAS ones but was developed for the 300 TDi. I have 4.56 in the diffs and at freeway speeds the RPM's are a little high and I have been considering going to the 1.2 t-case. This would reduce my RPM's at any given speed by about 429 RPM's. Sounds good to me. Of course, going the other way would increase your RPM's by the same amount. What I am proposing is finding someone to trade t-cases straight across. This would be perfect for anyone running 33in tires with stock gearing or someone that just wants to improve acceleration and 5 gear. The big difference is you are not making things weaker (like 4.10) and you are not shelling out $1000. Actually, it would be...FREE. Since I have a feeling this would be a really good option for a lot of people, I have a few things that would make it better for me. I want a t-case with around 40,000 miles on it or less. Mine has 40,000 and has been running royal purple gear oil for the last 2,000 or so. It is in perfect shape. I would also like it to be someone in southern Cali to make the swap really easy on both of us. If anyone is interested at all. Please e-mail me or just reply. Thanks to all!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 27th, 2004, 04:11 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
That's a great deal If I was living close to you I would've been all over this deal.
Good luck
World traveler
Old April 27th, 2004, 04:52 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
That is a great deal. That t case is aso great to run with 4.11 gears and 33"s or 35's. A perfect setup. THat is what I whave in my truck.
Legend in My Own Mind.
Old April 27th, 2004, 04:57 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey Randy,
You taken that thing out yet?? What RPM are you at in fifth at 70? Thanks
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 27th, 2004, 05:18 PM
It is a good deal, I have the 1.4 case and it helps allot with 35s". Now 5th is very usable on the highway. Hey Dave what RPMs are you dunning in 5th now?
Old April 27th, 2004, 05:22 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
I don't want to hijack the thread, but I have a question that is somewhat related.
What is a good RPM range?
I am assuming that higher RPM's = increase in wear and tear on the engine. My truck is stock, but I want to move up to 33" with a lift w/i the year. The real question then is whether 33's with stock gearing = more wear and tear on the engine.
Living in So Cal I feel like I won't be able to get by with the bigger tires w/o doing something. Reasoning: Automatic Trans, mountains, toll roads, and the 5 freeeway.
The truck is my DD, and I drive it about 24,000 miles/year, so I have been curious about this for some time. Maybe this is a good option instead of regearing.
Joe
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old April 27th, 2004, 05:28 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I have a 300 TDi and right now at 70 MPH I am almost exactly at 3000 which is just about the max RPM I am comfortable keeping the engine at for long periods. I think that 2571 would be really good for 70. I still need to see if I am accurate at the speed my speedometer says but this seems like a good solution, plus I could go lower in gears also in the future some time like 4.77 or 4.88 maybe, just thinking out loud and trying to see if this is a good idea.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 27th, 2004, 05:36 PM
Dave, 3k is a bit on the high side, but I have a friend with a tdi Jetta that runs 3k at 75mph and he drives 80 - 90mph all the time. Aat 3k does it feel like it has more then enough power? Even on the uphills?
Joe, with an Auto you will most likely need to regear. If Dave M is around he can chime in as he runs 33s on his auto 90, I know he regeared but I don't know what it was like before he regeared. I know on a manual 3k and 75 is pretty good on a light 90 and average hills.
Old April 27th, 2004, 05:41 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It has plenty of power on the flats for sure at 3k but up hills I have to back off because of EGTs. If I don't it gets hot pretty quickly but can motor up most hills no problem.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 27th, 2004, 06:02 PM
lobster's Avatar
lobster
Rob Goodall
1995 D90
In fifth gear going about 60 my tach sits at 3000. I have 35's and 4.75 gears. I am going to get a new transfer case when I swap out my 5 speed. The speedo says I am going 95 and usually kicks in the crappy governor.
1995 D90 ST
1999 Super V8
Old April 27th, 2004, 07:25 PM
jperakis
James Perakis
94 ST
dave as you know i just got that other Tcase, so i might be interested. gimme a call after 7 tonight. (650) 7765730
remember two things...
Old April 27th, 2004, 09:54 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Buckon37s, I have a 1.2 T-Case on the East Coast if you can't find anyone in your area who wants to do the swap. It came from a 97 Disco that had around 40,000 on it. I have put another 10,000 miles on it in my 90 Rangie, when I converted over to an LT230. Shipping would probably be around $50 through forward air. Let me know if you can't find anyone who wants to do it.
Pete
Rigless for now
1999.5 CC PSD - Tow Bus
If it looks like it works and it feels like it works...Then it works
Old April 30th, 2004, 11:41 PM
Rovertracks
Keith Kreutzer
Toooooo Many
I've got a good case in 1.2 If you are still looking Dave..
Lemme know
Keith
www.rovertracks.com
High quality parts for your Land Rover at a reasonable price!!!
www.rovertracks.com
Old May 3rd, 2004, 07:37 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks Kieth! I think I have a donor lined up but if it falls through I will call you, thanks to everybody too!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
body
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
