Every 94-95 D90 should have a Mallory unilite distributor n 1.4 ohm coil w no ballast - Page 3 - Defender Source
Old October 4th, 2013, 06:27 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
At Josh's request: http://youtu.be/4vyFJFWG4oE
Old October 4th, 2013, 10:19 PM
HAHAHA I love it. You are a brave man!!!
Old October 4th, 2013, 11:40 PM
Rock ware vice and drilling the dizzy shaft without a drill press were my fave moments.
Old October 28th, 2013, 12:13 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Ok, I am getting closer to reassembling the engine and dropping it in and I plan to order the Mallory and the new coil. My question is if I replace my dist & coil, can I ditch all this other BS surrounding the factory coil?
If I'm not mistaken, most of that is the garbage kit Land Rover came up with to patch their broken system from the factory right?
ID:	83046   Click image for larger version
ID:	83048   Click image for larger version
Old October 28th, 2013, 12:28 PM
Correct, if you are going with the fancy coil like we have. Tip, order an additional one of those Unilite eSpark ignition module things that go inside the Mallory distributor, as mine (and many others) came from the factory inoperable. It's pretty ridiculous, but Mallory knows they're going out broken to consumers a high percentage of the time and are not just send you a back-up one. Order everything from Amazon as it's the cheapest, and they refunded me a couple hundred bucks for my Unilite ignition module being messed up. I posted all of the parts and stuff that I bought, and as far as I can tell I came in a few hundred bucks cheaper than everyone else.
Also order a spare cap and rotor as I've read some have broken them during installation (I didn't, but others have).
Happy 10,000th post!
Old October 28th, 2013, 12:31 PM
Don't pitch the relocation kit though - someone with a stock setup could use it.
Originally Posted by pendy
I'm here for the D's
Old October 28th, 2013, 12:36 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Good call, I plan to keep everything I took out, by the time I'm done I'll have enough take-offs to build half of another car! lol
Old October 28th, 2013, 12:37 PM
I could use the relocation kit and associated crap. My NAS 110 does not have it.
90, 95, coil, d90, distributor
Question about Mallory Unilite distributor & Coil combination compatibility Neil McCauley Defender Technical Discussions 52 July 15th, 2016 08:38 PM
Theoretical ? regarding a mallory unilite distributor, coil and battery. Neil McCauley Defender Technical Discussions 16 December 16th, 2010 06:22 PM
WTB 94 or 95 D90 jefhuf Wanted 16 May 23rd, 2010 03:48 PM
Mallory Unilite Distributor Davis Defender Technical Discussions 5 April 9th, 2005 05:00 PM
Is it a 94 or 95 D90? PT94D90 Misc. Chit-Chat 5 November 12th, 2003 01:17 PM
