Evapo-Rust - Defender Source
Old June 13th, 2012, 04:54 PM
Evapo-Rust
It isn't often that I come across something that is a game changer for me in regards to vehicle maintenance and restoration. I saw this stuff in the hardware store and on impulse bought a gallon cz it was supposed to be non toxic. Mind you I have been derusting with Muriatic acid and that stuff is some awfully angry schmidt.
I tried a half bucket of Evapo-Rust with an overnight soak on a pair of shock mounts and all I can say is wow. They went from heavily crusted to looking like fresh castings. I had to scrub very little; just to take the dirt layer off after several hours. The next day they were clean, and I mean clean. Better than if they'd been glass beaded clean. Best part is that it is as benign as water.
I am not a spokesperson at all, just glad I found this stuff.
Yup, it turns to mud color right off the bat, but that doesn't reduce it's abilities...it's only suspended particles. You can return it to the container and use it over and over until it dries up.
It is meant for soaking parts in, not as a brush on treatment.
Old June 13th, 2012, 05:09 PM
I'm glad you're not posting photos of a before and after or anything like that... :SarcasticSmiley
Old June 13th, 2012, 06:21 PM
Thanks for posting this Bill...
Old June 13th, 2012, 06:30 PM
Sorry , those bits are over at the barn. Right now i have the rear calipers soaking from the rust-mobile parts Loooweeb. They've been in for 24 hours. Lets go see what they look like...
Old June 13th, 2012, 07:29 PM
Still a little bit of rust in the tight corners. Back in til tomorrow...
Old June 13th, 2012, 07:58 PM
Thanks for sharing!
Old June 13th, 2012, 10:33 PM
Billy post some pics....I want to see this stuff in action!
Old June 13th, 2012, 10:39 PM
JBinAlabama
john
Series 2A ..more parts on the way
Cool! So I'm not the only one here with some rusty parts
everything I have tried on impulse lately has been garbage.
I tried a "green" paint remover and it was like orange juice that did nothing to the paint!
Good find, thanks for sharing!
Old June 13th, 2012, 10:48 PM
Can I dip my entire Series in a vat of this stuff?
Old June 13th, 2012, 11:12 PM
Go see my man Ken at Chem Strip.
Old June 14th, 2012, 06:47 AM
Still soaking. Will check after work this evening.
Old June 16th, 2012, 10:11 AM
Well here is the result of a 4 day soak. When I say these calipers were heavily rusted I mean they had to have the pads beaten out of them. They were rust welded onto the rotor. As you can see the bores have been left untouched and all the threads are clean. I could probably leave them for another day or two to get absolutely every last molecule.
Keep in mind I had these on the workbench near the laundry and no complaints of chemical odors or what. In fact it has no odor at all.
I would recommend this product for all small parts derusting.
ID:	53067   Click image for larger version
Old June 16th, 2012, 11:30 AM
That's friggin' amazing! I just saw that stuff in HF yesterday. I'm going to have to add that to my shop, no make that garage, no make that little corner of garage collection!
rust on SW top overlap kolvedic Defender Technical Discussions 0 December 5th, 2005 01:51 PM
Rust Question Rob Defender Technical Discussions 0 August 29th, 2004 01:40 PM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
