Engine stand recommendation - Defender Source
Old March 28th, 2015, 05:36 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Can you guys recommend an engine stand that can fold for storage and won't feel like it's going to tip over when torquing down bolts?
Old March 28th, 2015, 05:48 PM
I always just get the cheap ones from Harbour Freight. Look for one that has the front castors as far apart as possible for better stability.
Old March 28th, 2015, 05:51 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Same for me, never had a problem with it. Used it for small block ford V8, small block chevy and rover. The MGB engine gave it the biggest work out though lol
Unknown Author
716-898-8153
Old March 28th, 2015, 05:56 PM
rankar's Avatar
rankar
The harbor freight ones can adequately support our v8s?
Old March 28th, 2015, 06:08 PM
Definitely, they are pretty light motors since they are aluminum. I can lift a short block by myself and I'm a weakling.
Old March 28th, 2015, 07:47 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Got a tdi on a small stand right now. When fully dressed its a little scary and flipping it takes two guys.
Old March 28th, 2015, 07:56 PM
Harbor Freight stands off of Craigslist. Half the price of new and they are taking up space that somebody else needs in their garage.
Old March 28th, 2015, 08:55 PM
I have several and trust none. I recently
Had to swap the engine in my f2fiddy and
the 7.3 weighs right around 1000 lbs. I needed
To swap everything from one engine to the
other. I put it on the floor and lifted ea as needed
with the hoist as necessary. I hate engine stands.
A good one costs a fortune. Saw one I'd like to have
On graveyard cars with a hemi engine on it, looked to
be up to the task.
Old March 28th, 2015, 09:23 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Here is my harbor freight special with a 3.9 that was going in the 110 on it. This is the cheapest one they sell.
And the Harbor Freight engine hoist
Unknown Author
716-898-8153
Old March 28th, 2015, 09:24 PM
That's the HF one I had that I didn't like, the front castors are too close together. It works fine, but I like the orange ones better for torquing head bolts.
------ Follow up post added March 28th, 2015 09:25 PM ------
Randy, can't you weld? Just buy a cheap one and modify it to suit your needs. You can add as much extra support as you want!
Old March 29th, 2015, 07:27 AM
rankar's Avatar
rankar
I guess Doug echoed my sentiments about stands, I just don't like them. Every time I see one, I think bumblebee... how on earth is this skimpy thing going to adequately support an engine?
Thanks guys for all the input. I'll give the harbor freight ones a shot.
------ Follow up post added March 29th, 2015 07:29 AM ------
Good point. I guess I just don't like to modify things like this unless I really have to. I'm afraid I'd overdo it and put another pair of front casters on
Old March 29th, 2015, 09:42 AM
I used one of these once and it was pretty awesome.
Old March 29th, 2015, 01:40 PM
rankar's Avatar
rankar
yeah that's pretty sweet. if i get that thing, then i better be ripping out my engine every six months!
Old March 29th, 2015, 03:14 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I got a set set of AC Delco stand and engine lift, the stand is good for my nearly completed blue printed 2 hondie tdi engine, I just love the engine hoist. I wouldn,t trust the stand with my 6 pot jag engines.
The ABC Delco can be got from O,Reillys.
If you are wanting a fold up stand you better stick to go cart engines
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 29th, 2015, 04:17 PM
How do you do the Camshaft on an pushrod engine? Maybe just for overhead cam engines?
-Jeff
It attaches to where the motor mounts bolt to the block. I like it because it allows to to bolt on the fly wheel, but you probably can't put on exhaust manifolds.
Old March 30th, 2015, 11:03 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Jumping in with a couple more stand questions.
Forgive my ignorance as I've never used one before.
Will a stand with a 750lb weight limit be enough for a 300tdi? or should I be trying to get a 1000lb limit.
Also will I be able to mount the engine so as to allow access to replace the rear oil seal?
Will
Old March 30th, 2015, 12:55 PM
Most engine stands will not allow for access of the rear main seal.
Old March 30th, 2015, 01:13 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
That's what I feared.... I guess I'll do with the engine in place then. Saves a bit of cash though.
Old March 30th, 2015, 01:26 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Will
CAN tire should have some options?
1000lb stand is usually more stable with the TDI on it but the 750 is sufficient (remember that you may be adding the equivalent of 150lbs of weight when torquing large bolts)
Yes on some stands having enough room in the Tdi mounting with room to access the rear seal - look at offset depth on the arms and mount them high on the block (limits rotation as the weight is far off center)
Old March 30th, 2015, 08:05 PM
I usually just use the engine hoist to hold the engine while I install the rear main seal. I've also just put the block on a work bench to do it.
engine
Engine Hoist and Stand Abrooks The Flea Market 10 December 5th, 2011 08:03 PM
Engine stand! JBinAlabama Misc. Chit-Chat 0 November 21st, 2011 06:08 PM
Engel Fridge Stand surf110 Smaller Projects 0 April 16th, 2010 06:02 PM
Is it ok to mount a 200tdi to an engine stand? dave_lucas Defender Technical Discussions 15 July 6th, 2009 12:34 PM
Engine Stand for 3.9L (Thread size?) Grover Defender Technical Discussions 1 April 13th, 2007 10:40 PM
