Engine stand recommendation - Page 2 - Defender Source
Join the Defender Source Community Today
Old March 30th, 2015, 12:26 PM
Mybluett's Avatar
Defenders Northwest
Originally Posted by Wilboro View Post
Jumping in with a couple more stand questions.
Forgive my ignorance as I've never used one before.
Will a stand with a 750lb weight limit be enough for a 300tdi? or should I be trying to get a 1000lb limit.
Also will I be able to mount the engine so as to allow access to replace the rear oil seal?
CAN tire should have some options?
1000lb stand is usually more stable with the TDI on it but the 750 is sufficient (remember that you may be adding the equivalent of 150lbs of weight when torquing large bolts)
Yes on some stands having enough room in the Tdi mounting with room to access the rear seal - look at offset depth on the arms and mount them high on the block (limits rotation as the weight is far off center)
Old March 30th, 2015, 07:05 PM
I usually just use the engine hoist to hold the engine while I install the rear main seal. I've also just put the block on a work bench to do it.
Engine Hoist and Stand Abrooks The Flea Market 10 December 5th, 2011 08:03 PM
Engine stand! JBinAlabama Misc. Chit-Chat 0 November 21st, 2011 06:08 PM
Engel Fridge Stand surf110 Smaller Projects 0 April 16th, 2010 05:02 PM
Is it ok to mount a 200tdi to an engine stand? dave_lucas Defender Technical Discussions 15 July 6th, 2009 11:34 AM
Engine Stand for 3.9L (Thread size?) Grover Defender Technical Discussions 1 April 13th, 2007 09:40 PM
