Electric Heater - Page 2 - Defender Source
Old November 11th, 2010, 01:03 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Does adding an aux jacket water heater take away from the warm up period on the truck. I would assume you would not want to engage this when waiting for the truck to warm up.
With the Webasto it uses a flame to heat the water then once the water comes up to temp it turns the fans on inside the vehicle (with the engine off, and keys not in ignition). The idea with Webasto is that the engine gets the heat first then the passenger?
If you are just looking for heat first thing in the morning your best bet is to get a block heater, and a cabin heater that runs off of 110 so when you go out to the truck in the am it is nice and toasty...That is what we did in Alaska.... where it got so cold we had to drive very slowly the first few hundred yards so the tires got round again.....
Old November 11th, 2010, 01:15 PM
Originally Posted by mgreenspan View Post
Why would anybody try to make sure something worked correctly first before upgrading it? Who does that?
Cheap people like me.
Old November 11th, 2010, 01:18 PM
Originally Posted by gliebig View Post
Do you think this one would work also?
http://www.jcwhitney.com/mojave-heat...lterid=c2448j1
This is the one you want... http://www.summitracing.com/parts/SUM-991102/ Would love to see a proper test and comparison versus a PROPERLY setup and running stock heater.
I will probably do one in the future and I will provide a scientifically based comparison with proper testing of airflow and heat output.
Old November 12th, 2010, 11:30 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'll replace the thermostat just in case. It's a cheap enough part. There is something wrong right, if the needle only goes up to 30-40% as opposed to 50% (dead middle of gauge)?
Originally Posted by Red90 View Post
Change the thermostat. It should get right up to normal temperature and not drop below. The intercooler has no affect on engie cooling.
Old November 12th, 2010, 11:38 AM
Plenty of Rovers sit right around 40-45% or right under mid point...fairly certain it's absolutely normal (at least I recall reading that it's absolutely normal). I know mine sits right around there about 80% of the time.
Old November 12th, 2010, 09:50 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Is this normal then? I have been driving for about an hour when this pic was taken.
Old November 12th, 2010, 10:26 PM
It is hard to judge as there are different sendrs and gauges through the years. They are not necessarily very accurate. You need a "real" gauge and sender that tell you an actual temperature to determine anything.
heater
cables to heater box ? mattdh Defender Technical Discussions 3 March 6th, 2006 09:33 AM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
