ECU Spare - Defender Source
Old January 31st, 2012, 12:47 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
ECU Spare
Looking for spare ecu's does anyone have a prefered source? Thanks in advance!
Old January 31st, 2012, 12:56 PM
eliaschristeas tends to find them all the time.
Old January 31st, 2012, 01:02 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I've gotten mine from ebay or random parts trucks. You can find them for around $100 a pop
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 31st, 2012, 08:11 PM
I bet tillery has one. I've gotten them from Elias also.
Old January 31st, 2012, 11:21 PM
I think I have accumulated a half dozen or so. I figure they will go up in value. Roverdude, roverguy, Paul Grant, etc.
Old January 31st, 2012, 11:25 PM
Bill Larson
Bill Larson
interested in letting 2 go?
Old January 31st, 2012, 11:30 PM
Not really. Plenty around to buy cheap and I like to have a spare for every truck.
Old January 31st, 2012, 11:36 PM
Bill Larson
Bill Larson
I have done the search...ebay...various sites, I know I'm over looking something. Guess I'll just keep my eyes open.
Old February 1st, 2012, 02:06 AM
I told you three people to check with. If one of them does not have one I would be shocked.
------ Follow up post added February 1st, 2012 02:08 AM ------
Wait, you are looking for a gems for a 97. Do disco I ecus work on 1997 d90s? I don't know.
Old February 1st, 2012, 09:02 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Depends on your definition of 'work'. As a spare, a Disco I ECU would be good, but not for the primary ECU. Unless you have the Defender chip set, it will throw codes. IIRC, the evac systems are different leading to at least that code.
Old February 1st, 2012, 10:34 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Depends on the year of the D1. 96 and part of 97 are the same. Mid 97 to 99 are different (Advanced Evap). Also needs to be put into learn mode before you can fit it the 1st time so it can sync with the 90's alarm ECU and forget the adaptive values from the donor. Or you could get it with the D1 Alarm ECU as a pair, but then you would still need to re-set the adaptive values and re-program the alarm ECU for the 90 (no remote door locks) so you're no better off.
Old February 1st, 2012, 11:08 PM
Bill Larson
Bill Larson
so whats involved with educating myself about ECU programing and such? could it be compared to using a bit writer 2 on an alarm system? just curious.
Mark- the D90 is still running hard and strong...thought you might want to know!
Old February 1st, 2012, 11:15 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
I am sure it can be done but they are protected. Black box who make the Rovacom started out by hacking the encryption and working out how to get in an play around with the variables of the various modules.
Not sure it would be easy to do though.
Old February 4th, 2012, 12:33 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Ian has it right. Get the ECU with the right chip set, then have a local indy Rover shop set it up for you as a spare.
Bill - good to hear, not surprising, but good to hear. Hope you and your family are enjoying the truck. Send me a PM with your address. I found the original window sticker and some other delivery materials I'd like to send on to you.
Mark
ecu, spare
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Interface on '94 ECU (OBD-I?) jaherring Defender Technical Discussions 10 October 11th, 2005 10:06 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
4 - 285/75/16's on stock D90 rims, 98% new, also spare & carrier januconn92 For Sale - Parts 7 October 13th, 2004 10:31 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
