Easy LR3 Part ID, Please? - Defender Source
Old August 4th, 2015, 01:58 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
All,
I'm an idiot, I understand that, as I should know what this is, but I don't, so I'll take all expected "you're an idiot" comments...but hopefully one will be followed by the ID of the highlighted part and some advice. I think it's part of the differential on my LR3, and I noticed some oil on it when I did an oil change last weekend. Not a ton, but it appears the rubber seal under the nut is weeping. Smelled of gear oil. I plan on doing the fluid changes on the diffs and transfer case in another 1000 miles as part of the 75,000 service. This is not the pic of my truck, but the best I could find online.
Thanks in advance,
Idiot
Name:	LR3 Pic copy.jpg
"It's not a Jeep"
Old August 4th, 2015, 04:52 PM
Rugbier's Avatar
Rugbier
Gustavo
That is the the that supports the axle shaft carrier
So the leak is probably the seal or maybe oil from the top dripping on it
NO SIGNATURE
Old August 4th, 2015, 05:09 PM
Originally Posted by Rugbier View Post
That is the leak that supports the axle shaft carrier
Fixed that for you.
Old August 4th, 2015, 06:19 PM
If you follow the passenger side axle shaft up you will likely find the axle seal is leaking. I would look in your engine bay next to the expansion tank for the axle breather which has a small one way valve at the top. Its a small plastic line coming up vertically and IIRC it is attached to one of the a/c lines. Clip the top of the breather off and that will probably greatly slow or stop the leak. There is an updated valve that you can put on the top, but I wouldn't bother.
Old August 4th, 2015, 10:48 PM
JBurt's Avatar
JBurt
Jesse McCoy
Jymmiejamz, still diagnosing RVA rovers from NYC.
Big thanks to everybody for helping me out.
"It's not a Jeep"
lr3, part
Easy Button :: 2006 Land Rover LR3 Greenbull Defender & Series Truck Registry 1 March 16th, 2016 03:42 PM
San Diego help please...? Looking at a LR3 APaden Wanted 14 February 3rd, 2011 04:45 PM
Fuse Box easy to replace? waveridin1959 Defender Technical Discussions 7 November 5th, 2005 08:11 PM
Draining Oil Made Easy Davis Defender Technical Discussions 14 March 5th, 2004 01:38 PM
Easy heater removal ??? artm Defender Technical Discussions 1 October 10th, 2003 08:27 AM
