Early 110s and 90s vs Defenders - Defender Source
Old December 9th, 2014, 11:23 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
Hey guys, I was just wondering about the difference between pre-defenders(Land Rover 110/90) and Defenders. Just curious. Thanks!
Old December 9th, 2014, 11:35 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Plenty...but not the shape.
Old December 9th, 2014, 11:51 PM
Landyman1's Avatar
Landyman1
Landyman
If it ain't broke, don't fix it. Fact: Land Rover Defenders are chick magnets. I once had two college girls on a highway (in a mustang) honk at me and yell cool car. They were probably drunk but as a highschooler, I never forgot it.
Old December 9th, 2014, 11:53 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I don't own one, but I believe the biggest difference is in the suspension. Someone correct me if I'm wrong.
The 90 and 110 have leaf springs similar to the old Series where as Defenders have coil over.
I'm just a stupid naive Discovery and Range Rover owner. But I did stay at a Holiday Inn Express last night.
Black Rhino Lives Matter
Old December 10th, 2014, 12:05 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Pre-Defenders had drum brakes in the back, thicker aluminium bodies and were less prone to electrolytic reaction. The front seats were a bit further out.
And the engines sucked. All of them.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old December 10th, 2014, 12:06 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Originally Posted by LuisC View Post
I don't own one, but I believe the biggest difference is in the suspension. Someone correct me if I'm wrong. The 90 and 110 have leaf springs similar to the old Series where as Defenders have coil over. I'm just a stupid naive Discovery and Range Rover owner. But I did stay at a Holiday Inn Express last night.
False.
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old December 10th, 2014, 12:14 AM
Landyman1's Avatar
Landyman1
Landyman
Originally Posted by Paul K View Post
Pre-Defenders had drum brakes in the back, thicker aluminium bodies and were less prone to electrolytic reaction. The front seats were a bit further out. And the engines sucked. All of them.
false. I have the 3.5l engine and it has never given me any issues. Then again, I do drive it every day so that really helps reliability.
Old December 10th, 2014, 12:17 AM
Earlier trucks had thicker body panels, galvanized body cappings. The differences between an early 90 and 110 and the 91 and up "defender" is simply the company named that series of trucks because they had introduced the "Discovery" and didn't want product line confusion. A 90 became a Defender 90 and a 110 became a Defender 110. That was the change.
Old December 10th, 2014, 12:21 AM
Took a lot longer for disc rear brakes to arrive than that!
Old December 10th, 2014, 12:22 AM
Landyman1's Avatar
Landyman1
Landyman
Originally Posted by ontheway View Post
False.
It actually came with range rover coils for suspension. Coil suspension in land rover 110/90s were the improvements it had over the series land rovers. That's the extent of what I know as a fact.
Old December 10th, 2014, 12:33 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Thanks for that enlightenment.
Don't recall from where I obtained that misinformation.
Where would we exist without these forums. Now if the members on range rover.net would get that. Their response is always "use the search tool". Like they don't want to be bothered.
Old December 10th, 2014, 01:40 AM
actually the 110 springs are considerably larger in diameter in the rear than range rovers and discovery's. All of the pre 1999 coil sprung trucks share the same suspension design and components but the springs and spring rates varied quite a bit. Some were linear some were progressive etc.
Old December 10th, 2014, 02:55 AM
Landyman1's Avatar
Landyman1
Landyman
I guess it must be for the County as mine has range rover type springs and they are the originals. Click image for larger version
ID:	108358 My buddy's F-150 has a massive lift kit on it. Just gives you an idea of how tall defenders are compared to normal cars
Old December 10th, 2014, 06:43 AM
rovertrader's Avatar
rovertrader
Dale
Don't forget the rear inner helper spring typically found on 110 HCPU and 130s...
Old December 10th, 2014, 08:01 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Overheat it once (except for Mark's engine), then the sleeves drop and push compression in the cooling system and the engine will be useless. It's a bad design without a lip in the bottom of the bore to hold the sleeve in place.
Pretty accurate...
RDavisinVA
Old December 10th, 2014, 08:46 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Disagree. Unless low power output isn't an issue?
ezzzzzzz
Mark Garrenton
^ not entirely true statement there. Yeah, the buick/rover block is not the best design but they take a lot more punishment than one overheating. My 96 4.0 Disco overheated multiple times until I figured out all of the problems. I never had to pull the heads. That truck is still in service by the fourth owner with +150k miles on it. The 3.5 low compression engine is less likely to overheat than it's newer stroked higher compression variants too. The engine design is seldom the root cause of a overheating situation. The water pump, fan clutch and radiator are the primary culprits. Most are unwilling to have the cross-flow radiator rodded or replaced due to inconvenience and stupid high cost.
Plus, the discussion of low power is mute. The logic of many is to install a TDi..... talk about low power! If you want reliability and power install a GM transplant. I ran a 4.3 V6 for 12 years until I spun a bearing in a bad mishap at Mountain Lake. I've got a LT1/ZF/LT230 going into my 110 and a LS1/4L60E/Dana300 sitting in my ongoing SIIA 88" coiler project
Old December 10th, 2014, 09:29 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I garrentontee you there is an exception to every rule.
You must have gotten the only rover V8 that the factory built to a high standard!
RDavisinVA
Old December 10th, 2014, 09:35 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
There's so much misinformation here.... Did Fox News sponsor this thread?
Old December 10th, 2014, 09:45 AM
Far too general. They're very similar in nature, but if we're talking about differences, there were some even within "pre-defenders" - i.e. depending on which range of years you're talking about, early 110s had differences when compared to later 110s (but still pre-defenders).
early 90/110s ignition key blanks ? Chris Velardi Defender Technical Discussions 7 June 12th, 2017 02:17 PM
Defenders, Defenders and more Defenders d90boy Wanted 13 March 25th, 2014 12:40 PM
Why 110s & not 90s? founD90 Misc. Chit-Chat 17 January 30th, 2011 11:27 AM
Early 110s ECR Misc. Chit-Chat 20 July 6th, 2008 09:28 AM
Stainless Bolt Kits for 90s and 110s Stmpede For Sale - Parts 33 March 17th, 2008 10:54 PM
