Dynamat vs Fatmat - Defender Source
Old September 4th, 2014, 09:10 PM
87 D110 (Ruby)
Dynamat vs Fatmat
OK ok ok - I know you get what you pay for blah blah....
But I am looking for someone with experience in a Defender with both?????
Anyone? I know it may just boil down to me paying for the Dynamat - but thought I would ask first.
Old September 4th, 2014, 09:12 PM
IMO the biggest bang for the buck comes from the Wright Offroad/Exmoor acoustic mat system. But I have limited knowledge or experience with land rover diesels.
Old September 4th, 2014, 09:21 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I have the acoustic system and I Dynamated the doors and cab. When I did the DM it did help even more.
Old September 5th, 2014, 08:04 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Jonesy, this is just my limited experience but the 110's that I've owned/driven that have all fresh bushings, springs, shocks, tires and balanced wheels drive like a dream. I often think a well insulated bonnet would be the first area of focus and then slowly move on from there. Ideally the engine side of the bulkhead would be sweet as well, killing two birds with heat and vibes.
Clay
Old September 5th, 2014, 08:22 AM
If you are interested in going up to see this guy in Maryland with me, he has several sound deadening solutions available. If we go up there we save shipping.
His main product is a loaded vinyl mat which you cut and fit into the footwells. These you then glue together to make a "bubble" inside that keeps the noise out. It goes in with hook and loop (velcro) so nothing is adhered to the panels. In all my research this seems like the best way to go even tho the up-front install is so finicky. The obvious advantage is that it is totally custom and you make it how you want it. I'm probably going to double up the thickness and then put my Hardura over it to hide everything. Should do the trick.
Old September 5th, 2014, 09:14 AM
ezzzzzzz
Mark Garrenton
I've used Secondskin products with great success in my 240Z but not in any Land Rover. The whole purpose is to kill harmonics (drone) at various frequencies, of course. A layering (or two) of the buytl/aluminum on flat panels will work wonders on killing the high freq noise which I find to be the most disconcerning as do most others. I also use their 'sludge' product which is sprayed on with a splatter gun. It too aids tremendously. Lastly, There is a closed cell rubber matting that absorbs low frequencies. In my Z, I could not hold a conversation at highway speed without damn near hollering. After treatment I can talk in a normal volume or listen to music at a respectable level.
Old September 5th, 2014, 09:15 AM
Its tough to know where to start, but I think under the hood has to be the first step.
Regardless of which brand, we use, my bias favors products that do not retain water.
Here is another brand I've been looking at.
http://www.b-quiet.com/ultimate.html
How much Dynamat to order for a 110? Yudda Defender Technical Discussions 9 November 16th, 2010 02:04 AM
Dynamat Grover Defender Technical Discussions 15 June 4th, 2009 08:11 PM
Dynamat TDI Guy Defender Technical Discussions 20 March 20th, 2009 07:55 PM
Dynamat extreme in Montreal Santiago Defender Technical Discussions 14 May 14th, 2008 12:10 PM
Dynamat or Ice & water shield JBOD77 Defender Technical Discussions 15 October 13th, 2007 11:00 PM
