Doorless...hmmm. - Page 2 - Defender Source
Old July 7th, 2012, 06:20 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I am not crazy about the look of my truck without doors but do love the feeling when driving...and as a side note, I am planning to build some tube doors for my truck in the next month or so depending on timing of completing some other small projects. I will post pics in a separate thread once underway if anyone is interested.
Old July 7th, 2012, 09:27 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
The trouble it seems with a doorless rover is the lack of a rim around the edge of the opening. In a jeep, there is a good six to eight inches of metal around the floor and along the outline of the entry way to help keep you and your belongings inside. Older jeeps without seatbelts had even more of a lip. The doorless rover also looks unfinished and jeep wannabeish IMO.
What is needed is something similar to the piece fitted on classic broncos. The original bronco roadster put an insert in the square opening to provide a more rounded finished look. It made the rider feel more secure, kept your stuff in the cabin, and made the truck not look like something riding out of the wrecker yard.
"Uhh...I think they all leak like that."
Old July 7th, 2012, 10:05 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Just curious but have you ever owned an early bronco? I had fiberglass inserts and soft doors for my first '69 bronco and they were awful! While aesthetically they were fine, functionally and structurally they were awful.
Old July 8th, 2012, 01:27 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I was also thinking an insert similar to what you mentioned on the Bronco would solve the incomplete look problem. Then I just figured you could build the tube doors having the bottom portion of the door frame covered in a piece of sheet metal painted to match the body. This way, when you have your door closed, it would look like you had that body insert already there. Plus you have something to keep empty beer cans on your floorboards from rolling out of the cab. The only downside I can imagine would be that your Defender would look THAT much more like a f@#$ing Jeep.
Old July 8th, 2012, 02:55 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
Tube door design, with integrated body panel (artists rendering)
Im no engineer, so disregard the tube door design. I do, however, have some photoshop experience...
Old July 8th, 2012, 02:57 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
P.S. Clay, thanks for the guinea pig.
Old July 8th, 2012, 06:17 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
That looks damn good... even from here in the UK!
Old July 8th, 2012, 08:02 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
For anyone who has tube doors, does it make more sense (for comfort) to have the top tube straight in line with the cappings (like the doors do) or to have a drop in it? I know in Jeeps they typically put the drop in because the top of the doors sits a little higher in relation to the driver. I find that the top of the ST doors is a very comfortable position for my arm while driving
Old July 8th, 2012, 09:21 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I kept going back and forth between straight top bar and dipped top bar while sketching this. I started the drawing with the straight top bar, and it just didnt look right. It looked more like a door frame that had its sheet metal ripped off than a purpose-built tube door.
Anyone have any thoughts about the lower panel? Should be an easy enough project...
Old July 8th, 2012, 09:51 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I like the idea of a lower panel as well and agree that the dipped bar definitely looks better...just worry about form over function to a certain degree
Old July 8th, 2012, 09:55 AM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
True, but I guess you'd be no worse off than you would be if you were driving without doors at all.
Old July 8th, 2012, 06:56 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Never owned a classic Bronco, but have ridden in them. Almost bought one before getting a jeep back in college. Can't really remember how well the inserts held up. I prefer metal doors with glass windows. Had both on my jeep - full metal for the hardtop and full soft with plastic windows. We get so much rain some type of door needs to be handy. Plastic windows on the doors got old fast.
Old July 8th, 2012, 08:46 PM
Straight bar on top for me. I have driven a summer without doors and like the feel more than the look, so I'll be trying some tube doors with Jeff too.
Originally Posted by pendy
I'm here for the D's
Old July 9th, 2012, 11:10 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
More like nothing to hang your elbow/arm on cause the tube door from RA is comes straight across from the hinge to the door latch. On an earlier thread there was calls for Wolf to work something up. From that last thread he I believe was trying to figure out the indemnify something paper for selling it.
Old July 9th, 2012, 01:13 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
It's still on the to do list, but at the bottom. The liability of selling "doors", which are designed to keep you in your truck, is huge. No signed piece of paper can prevent some idiot from sueing me.
Semper Fi!
Old July 9th, 2012, 02:00 PM
Naplm00
Matthew
true, I think most soft sided jeep doors come with a disclaimer saying they are not impact resistant
door
not mine, but hmmm, low miles jayz The Flea Market 1 July 15th, 2011 01:11 AM
Hmmm, how do I read this? Devin W Defender Technical Discussions 7 August 24th, 2007 09:17 AM
doorless jdb3760 Defender Technical Discussions 21 February 27th, 2007 09:08 PM
Hmmm, this looks interesting mikeslandrover Misc. Chit-Chat 16 November 26th, 2006 05:17 PM
hmmm... '98 90 on ebay Burke Misc. Chit-Chat 12 July 23rd, 2004 06:26 PM
