Discovery 1 stereo wiring + amps headache - Defender Source
Old May 30th, 2013, 02:27 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
can somebody school me on this?
Here's the current situation, right rear and rear door speakers (+ amp in the case of the rear door) don't seem to work. It doesn't look like power is going to the rear amp either. I'm not sure if there's a fuse blown, the amp is dead (apparently common) or both. I'd just like to fix it...
Any ideas?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old May 30th, 2013, 02:40 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Are you using the factory stereo?
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old May 30th, 2013, 04:24 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
No sir, a Kenwood that replaced the Kenwood that was already in it when I got it. I reused the wiring harness that was already in the dash.
~2008 GTI TSI
Old May 30th, 2013, 04:48 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
For the speakers, i wired from the deck to the outputs on the amp. The adapter that I had originally sounded awful. I'm not currently using the rear door speaker. I plan on replacing the speakers in it and rewiring it as well.
1995 Defender ST
1996 Discovery SE7
Old May 31st, 2013, 09:36 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Where is the other amp? (not the one in the rear door)
~2008 GTI TSI
Old May 31st, 2013, 09:40 AM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Passenger side footwell. Remove the glovebox for better access.
1995 Defender ST
1996 Discovery SE7
discovery, stereo, wiring
Stereo Wiring: ROW DNinety Defender Technical Discussions 9 May 2nd, 2011 09:52 PM
Stereo Wiring Questions gtg067i Defender Technical Discussions 1 June 19th, 2005 08:10 PM
Stereo Wiring Harness Manufacturer? priest944 Defender Technical Discussions 7 January 11th, 2005 06:03 PM
D110 Stereo wiring pcarey Defender Technical Discussions 1 November 23rd, 2003 10:57 PM
