Disco 1 no spark - Defender Source
Old May 17th, 2014, 05:29 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
Disco 1 no spark
my truck will turn over strong but has no spark. GEMS 4.0. I have replaced the coil pack, spark plugs/wires, crankshaft position sensor, ECM, battery. I have checked the fuses, relays ect. fuel pressure is good. any other things that i can check or that i missed?
Old May 17th, 2014, 06:29 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
When you replaced the ECM, did you do the security reprogram? The Engine ECU & theft alarm ECU have to be synched up or the ECU will not let the car start.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old May 17th, 2014, 06:50 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
no, no i did not. i suppose i need to find some one with the testbook thing or take it to a dealership...
Old May 17th, 2014, 09:18 PM
jafir's Avatar
jafir
Jafir Elkurd
Any other work done recently? Maybe something that could have bent the trigger on the flex plate?
Old May 17th, 2014, 10:23 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
Flex plate? No recent work done to it. It stems from when I went out wheeling and got "delayed". I had a constant drain on the battery (12v to <5v in 30 min), I got that fixed..now this.
Old May 18th, 2014, 10:41 AM
Check the wires at the crank sensor. Right near the connector there is some electrical tape wrapping the two wires together which is likely hiding some exposed wires.
Old May 18th, 2014, 11:24 PM
usmcxd's Avatar
usmcxd
Matt George
97 disco-Sold :(
I didnt see anything exposed but I didnt dig too far into that can of worms.
Old May 19th, 2014, 07:08 AM
You can just unplug the sensor and pull the wiring up to the engine bay. If you pull back the heat shielding there is electrical tape wrapped around the wires right at the connector. They will almost certainly have no insulation left on them. That might not be your issue, but its simple to check and repair.
disco
Good Spark, Bad Spark Big D Defender Technical Discussions 4 August 19th, 2008 09:43 AM
no spark suggestions? mattdh Defender Technical Discussions 12 April 25th, 2005 09:59 PM
SPARK PLUG Change Interval: norros Defender Technical Discussions 2 February 21st, 2005 03:03 PM
Spark plugs for a supercharged 4.0.. Tom Fitzgerald Defender Technical Discussions 0 May 10th, 2004 11:43 PM
Spark Plug Poll DJ Menasco Defender Technical Discussions 5 March 17th, 2004 07:12 AM
