Disco 1 Buying Help - Defender Source
Old October 25th, 2011, 12:56 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Disco 1 Buying Help
So my younger brother caught the Rover bug and wants a Disco. His budget is $3k. I know nothing about Discos, but does anyone have any advice or leads on trucks? It will daily driver, so it has to be "reliable," but he also wants to wheel it.
Cheers!
Semper Fi!
Old October 25th, 2011, 01:06 PM
I'd go with a 97 to get the BMW ignition sys and say goodbye to distributors.
Mark Kellgren
KM4BOR
Old October 25th, 2011, 01:12 PM
I would say, buy a 1998 LSE and sell the boost wheels to buy more off-road parts.
Old October 25th, 2011, 01:22 PM
carlosz's Avatar
carlosz
Carlos
3k shall be able to get you something very nice from mid 1998 (last yr the d1's were made), it will have the 4.0 gems engine and inmobilizer/alarm (sometimes it can be a pita specially if you loose the remote with the system armed).
issues may include, leaky sunroof, inoperable rear windows due a window controller issue easily solved with a dab of solder.
look for rust around the rear wheel well as you open the rear door, this is the rear seat shoulder belt anchor.
Alpine window seals can be a leak source thus running into the cargo floorboard and rusting it.
same goes for the front floorboards.
if the winshield has been replaced or if it will be replaced, make sure it has been done properly or it will leak down the "A" pillar, the right side houses the ecu... needless to point out the outcome.
all other oddities and eccentricities found in early rovers apply to this rover as well, anti lock light will not go off until you beging rolling the trailer light will light up when you first turn on the turn signal etc.
good luck..
Old October 25th, 2011, 01:26 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
There is something to be said about OBDI ('94 or '95 for a NAS Disco) due to simpler emissions and electronics.
Old October 25th, 2011, 01:34 PM
Trevor @ RoverLab had one for sale in that price range
Old October 25th, 2011, 01:41 PM
galen216's Avatar
galen216
Galen Lentz
'98 D1
x2 what Doug is saying. Trevor has gone through it and addressed the issues. Buying a Rover from Trevor is your best bet in that range. He also has an RRC with some off-road stuff in that range, but it needs a few things.
'98 D1
Old October 25th, 2011, 01:54 PM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks guys, I sent him an email
Semper Fi!
Old October 25th, 2011, 07:27 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
i am selling mine, needs a little bit of work. comes with tons of spare parts. we can talk about a good price if you are interested. its a 1999 D1 SD
Old October 25th, 2011, 07:45 PM
Wolf Fabrication
Sterling Archer
'08 D3
Sent you a PM
Semper Fi!
Old October 25th, 2011, 09:02 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Let me know if he starts looking at, or gets one and needs some help. I've owned 3 now (94, 98, & 96) and have dealt with many of the issues being discussed or what have you.
Trevor's current Disco is a good one, having seen it first hand, if you're looking for one that has had someone go through it and fix the big stuff. Not to mention its got cloth, etc.
There are a few on craigs that I'd be skeptical of but might be worth looking at depending on desired color and the aforementioned gap between the 94-95/96-99 (b/c there are some 99's floating around out there).
r-
Ray
buying, disco
Buying a Disco for parts maleger Defender Technical Discussions 11 July 19th, 2010 10:34 AM
Buying a 2000 disco II Lindy Defender Technical Discussions 2 July 23rd, 2009 12:09 PM
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 03:00 PM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
Garage Sale - 2ea LT-230, Hood.... RedRhinoProducts For Sale - Parts 10 November 22nd, 2004 08:12 AM
