Dip it - Defender Source
Old January 13th, 2010, 10:18 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Dip it
I have to say that I am impressed with Tool Dip It in a spray can. I'm feeling pretty waterproof with spraying it on electrical connections. Rubberized pretty good after a coat or two. I have also done the ecu but to overkill things, I found a plastic supplier that gave me all the scrap lexan I wanted for twenty bucks. I relocated it higher and made a clear waterproof box for it that is practically break proof.
I finished completely sealing the distributor and running two small sections of hard plastic tubing through the cap on the sides. I'm pushing vacuum through it at all times running.
Think I'm almost ready to dunk her.
No more fan either.
Shrouded aluminum radiator with electric and kill switch.
Going to take care of the fuse panel and the coil on Saturday.
And hay
And I love you too
Old January 13th, 2010, 10:25 PM
Take video (and share) when you dunk her!
Old January 13th, 2010, 10:30 PM
You are putting a vaccuum on the distributor cap?
Old January 13th, 2010, 10:32 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I'll try to do that. I'm not trying to build a boat, but I would like to get it pretty deep close to home so that I can fix anything I have missed. I just am trying to build the thing to be ready for whatever happens.
------ Follow up post added January 13th, 2010 09:32 PM ------
yes sir
------ Follow up post added January 13th, 2010 09:34 PM ------
running constant vac through it from the brake booster to eliminate condensation buildup from the unit being completely sealed
------ Follow up post added January 13th, 2010 09:35 PM ------
liquid electrical tape is really cool also
And hay
And I love you too
Galvanizing question Mark McDonough Defender Technical Discussions 25 November 4th, 2009 08:41 PM
head gasket blocking dip stick. sflash868 Defender Technical Discussions 6 November 2nd, 2007 09:27 AM
New Series III Turn / Horn / Dip Stalks SafariHP For Sale - Parts 0 January 22nd, 2007 11:17 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
can I remove a/c compressor belt? Campbell Defender Technical Discussions 20 November 1st, 2003 10:07 AM
