Different kinds of diesels - Defender Source
Old January 25th, 2005, 09:19 PM
rustydefender
Russell Newton
97 D-90 sw
Anybody fitted any diesels or any other engines for that matter aside from 300 tdi's and 4.6's. Seems like just about anything could fit under the hood.
Old January 25th, 2005, 09:50 PM
Well there have been some others, Chevy 350s and 6.5 Detroit diesels. In Austraila some Defenders came with Izuzu 3.9 diesels. There are some guys with Series rigs running Cummins motors, mostly 5.9s. What are ya thinking?
Old January 25th, 2005, 10:02 PM
rustydefender
Russell Newton
97 D-90 sw
I dunno, just want a diesel really bad. I prefer the powerstrokes you can get in ford trucks. Probably looking for the best power possible.
Old January 25th, 2005, 10:17 PM
Well I think There was some talk of the PSD, but I think it was going to be a tight fit, allot of other problems like cooling that big of an engine, fitting an axle under the oil sump, and upgrading the drivetrain because of all the extra power. It would be a major job, I'm not saying it can't be done but it's allot of work and a bit of doing the never done before. I think the PSD would be a bit more power then you would need though?
Old January 25th, 2005, 10:22 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I looked into sticking a used 7.3 Power Stroke and was told its too big,too heavy,too powerfull. That it might work in a 110 but I'd ahve to take the drive train out of the ambulance donar.
Jimmy Buffett
Old January 26th, 2005, 08:50 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Their has been a bunch of discussion about the powerstroke 3.0 on the tdi yahoo list. Sounds interesting, but it comes with an ECU, mandatory. I think once you get away from the smaller diesels, you begin to lose some of the benefits of diesels. The other problem you have is drivetrain, of course. Too much torque and boom.
EDIT
Interestingly enough, I found this post on the RN board:
Posted by andreas on 01/17/2005 09:59:45 AM:
For those of you always dreamed of converting your series LR to Mercedes power, I have for sale the following:
Adapter for 4 and 5 cyl turbo and normally aspirated mercedes diesel engines from '75 to '89 (OM 616.xxx, 617.xxx, etc) to 4 OR 6 cyl LR (80/86/88/90 107/109/110). Adapter made/machined in Germany with both the 4 and 6 cyl gearbox bolt patterns from 1018 plate. Included is the correct flywheel, pilot bearing and pressure plate and mounting studs. Adapter will work with both 4/6CYL 4SP and 5SP gearboxes with the appropriate clutch disc.
Also FS:
1 of 5cyl normally aspirated Diesel Engine 1982 vintage (never installed).
1 of 5cyl turbo diesel Engine (OM617.952), good for parts or rebuild (needs piston rings).
This series of mercedes engines give the added benefit of being able to run/start on SVO and bio-diesel without modification to the engine.
I can deliver to Northeast US/Canada. I will box ship adapter, etc. worldwide at cost.
email to-->andreas*bio-diesel*org
Old January 26th, 2005, 04:49 PM
rustydefender
Russell Newton
97 D-90 sw
I would like a 300 but I have not really heard much about them in the category of reliability. I'm sure because of their popularity it is an excellent engine but I do not have any experience with them and neither does just about any local mechanic. How is a 300 tdi compared to maybe a 2.8 power stroke. In terms of price, performance and reliablity? If I were to get a diesel how much of the powertrane would I need to change.
Old February 1st, 2005, 03:48 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I think you'd be looking at changing the main gearbox as well as the engine, the bell housing & input shaft are different I think. depending what size tyres you run you might need to change the transfer box too for a 1.44:1 ratio job. I think you'll have a 1.22:1 at the moment if you've got a V8 under the bonnet.
Mind you my 200 tdi discovery pulls a 1.22 transfer box just fine with 235/70 R16 rubber. Infact it's faster up a local hill than my 110 with a 1.44 transfer box & 235/85R16 tyres.
Mike Hammond
Old February 2nd, 2005, 02:55 AM
whistler110's Avatar
whistler110
Mike Johnstone
ex-mod 110
The HS2.8 is based on the 300TDI and shares it's engine mounts. The 2.8 has more power and torgue, I can't remember the exact numbers.
If you stick with the 2.8 or 300TDI you could leave your driveline in place. What most will suggest is to replace the transmission with a diesel R380 but there is a guy on roverlanders.bc.ca that installed a 2.8 in front of a V8 R380 transmission in an ex-mod 110 so it has been done. He said that one of his reasons for using the V8 R380, instead of the shorter diesel version, was that it is more common in North America.
Bike Mike
Old February 2nd, 2005, 09:29 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
David, I am quite friendly with Andreas and he actually was down from Canada yesterday and stopped at my house to check out my 90. I have driven one of his 109's with a MB TD engine. ITs a lot of fun. He builds some really cool stuff. I got a 2.0 perkins prima from him that I will use to build a hybrid IIa eventually. I also had his IIa with the same motor out for a spin and that was a blast. IT also got 40mpg on the highway and he drive it straight from Wolfsville Nova Scotia To NJ over the summer with no problems.
Legend in My Own Mind.
Old February 3rd, 2005, 12:30 PM
mikeslandrover
Mike Hammond
Is the bolt pattren the same on the V8 and 300tdi
Very cool if it's a straight swap but I thought the bolt pattern was different?
Mike Hammond
Old February 3rd, 2005, 02:36 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Has anyone used East Coast Rovers to do a 300 tdi conversion. What does it cost, are they reliable. I have 42,000 on my 95 v8 motor and wonder if I should wait till I rack more miles before I convert to diesel. I hate to take out a perfectly good engine. How much can you get for a used v8.
Matt...
Old February 3rd, 2005, 03:45 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Matt, contact Pendy who posts on this board. He can help you with those questions and is more local to you in the midwest.
Old February 3rd, 2005, 03:49 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Talking
Dave,
I am starting to get a little worried, I was talking to the guys at Rovers down South and they recommended that I check with Pendy also. Starting to think there may be some cult thing going on. I wont have to drink any cool-aid will I?
Matt...
Old February 4th, 2005, 10:04 AM
D110XD's Avatar
D110XD
Michael-P. Richter
110 HT XD 1997
The best engine you can put into a defender is definetly the 2,8 Powerstroke.
Based on the 300tdi, it has more torque and power. As the 300tdi (2.5 l tdi) it is veeery reliable, powerful and you need only 10-11 liters diesel per 100km. It is more powerful than the standard defender v8.
Another option is the already mentioned 3.0 Isuzu or a 2.8l diesel built in the spanish Santana PS10 defender derivate.
Or the LR TD5 engine which is built in the european defenders. You can get 400NM torque and 200 horses out of it.
Michael
Old February 4th, 2005, 12:37 PM
whistler110
Mike Johnstone
ex-mod 110
I have seen an adapter plate for V8 conversions into Discos sothat would probably be the easiest. Something else to look at would be the back plate, HS 2.8's don't come with one and you have to put one from a 300TDI on. The V8 back plate may fit as well, but don't quote me I'm just theorizing.
Bike Mike
Old February 9th, 2005, 01:20 PM
LRover's Avatar
LRover
J. Michael McCaig
The GM 6.2 is fairly popular in GB but I believe folks have a bad feeling here whenever someone mentions GM and diesel together. I saw a 6.2 in a Disco and it seemed like a nice conversion and supposedly was only about 70 lbs heavier than the 300tdi. I have been seriously toying with the idea of converting my 110 to the 6.2.
Old February 9th, 2005, 02:50 PM
D110XD's Avatar
D110XD
Michael-P. Richter
110 HT XD 1997
What are the advantages of this GM 6.2 compared to a td5 or 2.8 powerstroke?
It needs more gas/diesel and I don't think it outperforms a good Tdi/Td5 Engine (i.e. 204bhp, 400N torque).
If you want a big, strong diesel that aditionally has a low diesel consumption I would take this:
Mercedes 400CDI, 250bhp up to 320bhp, ~600N-650N torque, 4l 8cylinder. 12-15l diesel...
Another very good engine is the Toyota 4.2l NA diesel. There are some Defenders on the road w. this engine.
I 've driven one and was really amazed...
I like the GM petrol engines, but in diesel technology I'd prefer the above...
Michael
Old February 9th, 2005, 03:36 PM
whistler110
Mike Johnstone
ex-mod 110
The GM is a simple easy to obtain and inexpensive engine. It puts out that power without a Turbo system, it wieghs less than most engines of that size and isn't that bad on fuel. I'm not saying it's the answer to conversion needs but it does have it's strong points.
What I think is funny is that many here in NA want a TDI and a many in the UK want a GM.
Grass is always greener on the other side.
Bike Mike
Old February 9th, 2005, 08:25 PM
rustydefender
Russell Newton
97 D-90 sw
GM 6.2 eh, that would be the duramax for the silverado you can do some crazy mods from banks performance that can put out some ridiculous power.
diesel
mpgs for diesels? Z O O R O P A Misc. Chit-Chat 145 April 26th, 2013 04:02 PM
4 x defender 110 (1983) diesels rovernutzz For Sale - Vehicles 10 June 20th, 2008 02:01 PM
synthetic 15w-40 in diesels...watcha think? D90user Defender Technical Discussions 10 April 1st, 2008 05:26 PM
Rumors Ford will use Land Rover sourced diesels on 2009 F150 DBZ2009 Misc. Chit-Chat 4 May 3rd, 2007 07:15 PM
Diesels R.B.Bailey Misc. Chit-Chat 53 November 28th, 2003 08:33 AM
