Diff Carnage - Defender Source
Old June 14th, 2004, 12:13 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Diff Carnage
ID:	833   Click image for larger version
Pete
Rigless for now
1999.5 CC PSD - Tow Bus
If it looks like it works and it feels like it works...Then it works
Old June 14th, 2004, 12:17 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Is that how it looked when you pulled it out?
Chris von C
[/size]
Old June 14th, 2004, 12:18 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Yup, just yanked it 10 minutes ago.
Pete
Rigless for now
Old June 14th, 2004, 12:21 PM
tbmcneill
Guest
Posts: n/a
what ratio was it?
Old June 14th, 2004, 12:26 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
4.10 from GBR with less than 15k on it and alot of wheeling trips...My guess is when I was high centered on the rocks I was giving a fair amount of throttle in reverse trying to get off. So this meant I was riding on the weak side of the reverse cut gears and boom.
Pete
Rigless for now
Old June 14th, 2004, 12:42 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Throttle Jocky...... That looks ugly Pete. Maybe Vinny has a set of 3.54's you can swap in for now..
Legend in My Own Mind.
Old June 14th, 2004, 12:47 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Yeah, but then I have to swap the rear gears to 3.54. And I can't beat ricers off the line with the stock gears. I'm actually liking the 2wd since I can finally do donuts
Pete
Rigless for now
Old June 14th, 2004, 12:55 PM
tbmcneill
Guest
Posts: n/a
that sucks, man. been there, though..... gotta love those rover diffs... especially with the lower gears
Old June 14th, 2004, 01:05 PM
That sucks man! I'll have to get some pics of mine tonight when I pull it out.
Old June 14th, 2004, 01:31 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Pete, you need a diff? I am almost positive I still have the front out of my Disco when I put in the TT. Mike let me know about the rear when you get a look at yours.
Chris von C
[/size]
Old June 14th, 2004, 05:47 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Thanks for the offer Chris, but I'm gonna go to a Toyota 3rd, 30 spline shafts and Longfields.
Pete
Rigless for now
Old June 14th, 2004, 05:51 PM
whats longfield isnt something that is done to make the birfield? stronger??
Old June 14th, 2004, 06:29 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Bobby Long reworks stock Toyota CV joints to make them pretty beefy. Toy guys are running 38's without breakage http://www.longfieldsuperaxles.com/
Pete
Rigless for now
Old June 14th, 2004, 07:01 PM
But is that with an old 4 banger and a lighter truck? I don't imagin you will be running 38s but you do have a V8. And how much work to get them to fit if any?
Old June 14th, 2004, 07:23 PM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Angry
Aussie guys are running the Toy stuff in their LRs with 35s or 38s with pretty much no problems. Here's a run down of what has to be done.
Rear:
Remove diff studs, close holes, redrill for the Toy diff pattern, reinstall studs
Redrill for LR driveshaft pattern
Machine spindles ~20 thousands to clear the 30 spline shafts
Add New 30 spline shafts/driveflanges/diff w/ your gear choice + locker
Front:
Machine spindles/swivel ball ~20 thousands to clear the 30 spline shafts
Machine spindle to run Toy bushing
Add New 30 spline shafts/CVs/driveflanges/diff (HP only) w/ your gear choice + locker
It's a fair amount of work, but nothing thats rocket science. The rear should be pretty easy and done in a weekend once I get the parts. My plan is to do the rear first and sell all of the LR stuff to fund the swap for the front. This swap seems more economical and easier than doing 60s or whatever because I can keep my housings and wheel/tire combo. If all goes right I won't have any real down time since this is still my DD.
Mike, did you pull your rear yet to see whats wrong?
Pete
Rigless for now
Old June 14th, 2004, 09:48 PM
Ahh some nicely damaged gears . Looks like I need some stuff. Oh and there was no problems with the front, the park break screw fell out! Good thing I put one of the driveshaft bolts back on! I put another on and torked them both down and NO more noise!
ID:	842   Click image for larger version
Old June 15th, 2004, 09:19 AM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Nice Mike, atleast you didn't blow up the front aswell.
Pete
Rigless for now
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
QT Services Diff Guards and HD Engine Mounts JohnC The Vendors Loft 1 February 16th, 2006 09:53 PM
110 rear diff protection (Salisbury diff guards) dave_lucas The Vendors Loft 13 October 25th, 2005 09:08 AM
need front/rear diff for 1994 D90 rover_rich_d90 Wanted 4 March 14th, 2005 09:05 PM
