Diesel compression tool. - Defender Source
Old May 16th, 2014, 11:44 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Anybody have info on a compression testing set-up for the rover tdi? Time to buy more tools....
------ Follow up post added May 16th, 2014 11:45 AM ------
P.T.?
Email is
Same place, new dogs.
Old May 17th, 2014, 11:20 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I use a Snap-on MT33C compression gauge. The Snap-on EEPV314A adapter will fit the Tdi engines through the glow plug holes. I also have a Snap-on M3571 adapter that I have modified to work on the 2.5NA. This adapter goes in place of the injector. I had the nose reprofiled by a machine shop to match the injector.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
diesel
200tdi compression tester Macker Defender Technical Discussions 8 October 7th, 2015 01:04 PM
Gasket Heads -> Compression Ratio aaronlam Defender Technical Discussions 9 December 10th, 2011 08:36 PM
Blue Smoke While Under Compression outfield Defender Technical Discussions 7 April 3rd, 2010 03:13 AM
Compression testing a 300tdi Hoosier Defender Technical Discussions 3 May 28th, 2008 03:29 PM
Compression Test Results... need help interpreting them martym Defender Technical Discussions 12 March 3rd, 2005 09:46 PM
