Did LR make a 3.5 v8 for thier 1985 d90s? - Defender Source
Old May 17th, 2012, 09:09 PM
egor
kody martin
1986 Land Rover 90
If they did, how reliable? From what I understand, they are not fuel injected.
Old May 17th, 2012, 09:20 PM
Yes.
Old May 17th, 2012, 10:54 PM
The Dro
Dro
1988 Ninety
The Land Rover Stage 1, Range Rover, MG, Triumph... Other British car too had the 3.5L. aka the Buick 215.
Old May 17th, 2012, 11:42 PM
carlosz's Avatar
carlosz
Carlos
correct, they are not fuel injected, they use two stromberg carbs, one per bank, as per reliability, they are a bit underpowered, the bottom end is not cross bolted (4.0 and 4.6 are cross bolted) and if the oil pump looses prime you need to pull it apart and fill with vaseline in order to prime... they leak just like any other rover and because they are multy belt drivers, rotating parts such as water pump and power steering are becoming a little hard to locate... the 3.5 is the only of the v8s to have a small cylinder bore all others have large bore cylinders shared among... the heads are shared among all rover v8s, the change is in the valve stem after 1990 to reduce accumulation of carbon.
the 3.5 had a metal head gasket which is later replaced by composite, there is a little work to be done with the job... bell housing pattern is shared among v8s, so technically you could take a later 4.6, 4.2,4.0 or 3.9 and drop it in place of a 3.5...a little work is in oder so a few things can be transfered from the 3.5 to the 4.6
1985, 90, d90, v8
D90s Operating in Today's Pakistani Offensive wicks Misc. Chit-Chat 4 March 18th, 2004 08:14 PM
best shop in the Boulder area for servicing (general) D90's? snosrfr Defender Technical Discussions 8 February 9th, 2004 10:50 PM
what's a good pricing guide for D90's? januconn92 Misc. Chit-Chat 4 January 11th, 2004 01:53 PM
D90's in Highlands Ranch CO! TwisteD90 Misc. Chit-Chat 24 January 6th, 2004 05:35 PM
do 1997 california d90s have extra smog stuff? tomken Defender Technical Discussions 3 January 4th, 2004 03:55 AM
