Diagnosis question - Defender Source
Old November 3rd, 2015, 03:03 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Diagnosis question
Ok, so if your waterlogged LR3 carpet has current flow, is that a water leak or a voltage leak?
Email is
Same place, new dogs.
Old November 3rd, 2015, 03:16 PM
Mark Kellgren
KM4BOR
Old November 3rd, 2015, 03:25 PM
Roverlab
Trevor Griffiths
Came in for a water leak issue- water would flow out of the headliner at the sun visor. Ok, clogged drain in the tray seems a reasonable place to start. Sunroof wont open. Diann says it did work just last week.
Faults for issues with the sunroof ECU and the rain sensor, which share a Local Interconnection Network bus. The sill has maybe an inch of water, fully covering a big fat wiring harness running in the sill. I suspect a Splice maybe slightly corroded, possibly allowing current to flow through the drenched foam and carpet.....
Email is
Old November 3rd, 2015, 03:34 PM
Rovers should not be driven in the rain.
Old November 3rd, 2015, 03:37 PM
It does not rain in the UK making it hard to test.
Old November 3rd, 2015, 03:42 PM
Roverlab
Trevor Griffiths
Or without AAA.
This might be the problem:
Email is
Old November 3rd, 2015, 03:58 PM
Is there a water ingress manual for new Rovers?
Roverlab
Trevor Griffiths
And this:
Email is
Old November 3rd, 2015, 04:03 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Was something tapped there and it got pulled apart?
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
Old November 3rd, 2015, 04:08 PM
Roverlab
Trevor Griffiths
The blue stuff is Gen-u-ine Land Rover production waterproof non-conducting color stable 'lectrical tape.
Email is
Old November 3rd, 2015, 04:20 PM
It also does not rain in my garage which is where they belong.
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Nothing like an inline splice.
They are not allowed in my industry (mass transit).
Old November 3rd, 2015, 04:44 PM
NEVER cut the RED wire!!!
Mark Kellgren
KM4BOR
Old November 3rd, 2015, 05:36 PM
Roverlab
Trevor Griffiths
Ooops, forgot the video
Email is
Old November 3rd, 2015, 05:37 PM
Roverlab
Trevor Griffiths
Hmmm
Email is
Old November 3rd, 2015, 05:57 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Do the guy a favor and redo the green/white wires while you're in there
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old November 3rd, 2015, 07:32 PM
Land Rover doesn't even use solder on the splices. The wires are twisted together then I guess hot stamped?
clutch problem diagnosis help... bharris Defender Technical Discussions 18 November 14th, 2011 04:42 PM
need help with diagnosis of 3.9 fuel problem Art Vigil Misc. Chit-Chat 15 July 7th, 2010 01:07 AM
Trail break diagnosis phoenix37 Defender Technical Discussions 15 July 27th, 2009 02:41 PM
OBD2 - P0420 Diagnosis pcscharfe Defender Technical Discussions 1 January 12th, 2008 02:28 PM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
