Detroit /true trac locker question - Defender Source
Old March 7th, 2016, 07:48 AM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
How do I know if I need a 10 spline or 24 spline locker in the rear? I was trying to research it and it seems that the Disco 1's were 24 spline but how do I know for sure? Thanks in advance.
1995 Disco 300TDI
1991 D130 (SOLD)
1997 D90 NAS (SOLD)
Old March 7th, 2016, 07:53 AM
rovertrader's Avatar
rovertrader
Dale
All NAS D-Is are 24 spline. But, if so inclined, simply pull one and count the splines at the diff end. If you have steel wheels and open centers, simply unbolt the 5 inner bolts ( on the drive flange) and pull it out- short side is easier to reinstall your first time.
Old March 7th, 2016, 08:01 AM
NAS D90's to be specific. 110's are 10 spline in front. and 24 in rear for clarification of future readers
Mark Kellgren
KM4BOR
Old March 7th, 2016, 08:05 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
The Detroit TrueTrac is an LSD.
Old March 7th, 2016, 08:20 AM
OP asked about D1, not D90.... Just saying
Old March 7th, 2016, 08:53 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Pulling a shaft is pretty simple and straight forward. Like rovertrader said, if you have steel wheels you don't even have to pull a wheel off or jack it up. Otherwise just jack up one side, pull the wheel. Then pull the five bolts holding the cap down. It should slide out pretty easy. You may get a bit of 90wt oil that will drip out when you do this.
Old March 7th, 2016, 09:38 AM
mightymo's Avatar
mightymo
matthew m
'95 Disco 300TDI
Originally Posted by down_shift View Post
the detroit truetrac is an lsd.
lsd?
1995 Disco 300TDI
1991 D130 (SOLD)
1997 D90 NAS (SOLD)
Old March 7th, 2016, 09:42 AM
Originally Posted by mightymo View Post
lsd?
Limited slip diff.
ac
Range Rover Classic True Trac Diff Jonesy For Sale - Parts 15 September 17th, 2014 03:51 PM
FS: NIB Detriot True Trac (front) 24 sp w/ timken bearings $450 shipped Scottg For Sale - Parts 2 September 19th, 2012 12:21 AM
GBR Detroit/True Trac, 4:11's, and Rovertracks axles Alberto_SD For Sale - Parts 6 September 17th, 2010 01:29 PM
Detroit True Trac for sale billnsandi For Sale - Parts 4 December 28th, 2004 05:25 PM
Stock Diff w/ True Trac James Pierce For Sale - Parts 1 August 31st, 2004 08:26 PM
