Defender Towing Capabilities - Defender Source
Old June 5th, 2013, 10:19 AM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
I'm about to blow the dust off of my 20' jet boat, and plan to use the defender for towing purposes, since it's my only vehicle other than a Vette now...
Are NAS D90's capable of towing/backing a boat of that size? I had a Chevy Silverado (2wd) that had a hard time backing the boat up my semi steep driveway and into my garage, so I'm hoping the Defender has enough juice to do the job.
Old June 5th, 2013, 10:25 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
http://www.defendersource.com/forum/...5&postcount=10
I used to pull my 24ft Baja go fast boat on a dual axle galv trailer with a 94 nas 90 with no issues. The trailer was much easier to back down my driveway with the 90 than with the 110.
http://www.defendersource.com/forum/...441#post299441
http://www.defendersource.com/forum/...886#post302886
Old June 5th, 2013, 10:30 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Yeah, TONS of posts on this topic...all good stuff. Search.
Old June 5th, 2013, 11:17 AM
WD90's Avatar
WD90
Dan
Will do! Thanks for the responses!
Will low gear help as far as backing the boat up my driveway and also pulling the boat out of the lake?
Old June 5th, 2013, 11:27 AM
If you get another Chevy/GMC/Ford or other full-sized truck in the future, get a front hitch and you will be golden.
I have a similar problem, backing my car hauler into my bottom driveway was tough in my YukonXL because of a tight turn, but the RR was easy due to the shorter wheel base. Once I picked up and installed a front hitch, it was very easy and quick.
Old June 5th, 2013, 03:29 PM
WD90's Avatar
WD90
Dan
I removed the two ballcaps that were covering up my low gear shifter, and I was like, "doh"... the 90 pushes the boat up my steep driveway almost idling... I know it can handle garaging and launching the boat, just curious about hauling down the highway now. I'm sure my mpg will drop to around 5-6
Old June 5th, 2013, 04:12 PM
Rugbier's Avatar
Rugbier
Gustavo
Not sure if your " Jet Boat " is the seadoo/yamaha style ( I have a Yamaha SX210 ) and I have towed it with my D-90 with 2" lift , an-strapped and un-sawyed, no issues unless I was passed by an 18 wheeler or I found myself to slam the brakes ( then it wandered a tadd ).
I have a pretty f@#ked steep driveway as well , and I have always backed in with no issues, now remember the tongue position is a lot different than a truck, so the little change in steering will move your boat quite a bit
NO SIGNATURE
Old June 5th, 2013, 04:55 PM
WD90's Avatar
WD90
Dan
You got that right... thankfully I had an extra set of eyes to help me steer it into the garage. My trailer is so wide, I have about 1" of space on either side of the wheels and my garage door.
It's a 20' fiberglass raceboat... I'd post pictures, but I just chipped a layer of old paint off of it and sanded the old gelcoat in preparation for fresh paint. It has a Chevy 350 and the interior was soaking wet, so although it's a small boat, it's not that light.
My driveway is about 25 degrees uphill, and my attempts in high gear were unsuccessful.
Old June 5th, 2013, 05:23 PM
Rugbier's Avatar
Rugbier
Gustavo
I always done it on did flock , and high gears, no need to be on low
NO SIGNATURE
Old June 5th, 2013, 06:27 PM
WD90's Avatar
WD90
Dan
I feared that I would chew up my clutch trying it in high gear. Fitting my boat into my garage is literally as tedious as threading a needle.
Old June 6th, 2013, 05:22 PM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
My 110 3.5 V8 towing my 10 ton truck.
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old June 7th, 2013, 07:36 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Here I am towing, uh..... Dragging a small barn down a gravel road...
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old June 7th, 2013, 12:00 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I towed 6,000 behind the defender, unbaked for 400 miles. No sway bars, 2 inch lift. I did the speed limit, never saw fifth gear, and had to stop for gas every 20 minutes but it was fine. Careful stopping otherwise I wouldn't think twice about a jet boat.
I used low range to move that load around in my driveway (which is very steep)
Old June 7th, 2013, 12:38 PM
On any boat ramp/steep driveway between the weight/slope/slipperiness makes Low range diff locked the only way to go to avoid getting embarrassed by the Chevyfordodge crowd
Old June 7th, 2013, 02:53 PM
WD90's Avatar
WD90
Dan
There were some Dodge neighbors snickering at me the night that I gave up before realizing I have low gear... I was about to borrow one of the vehicles from the dealership and back it in there... then
Old June 7th, 2013, 03:55 PM
Before Low Range
After Low Range
Chevyfordodge owners go
Old June 8th, 2013, 06:33 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
This is the 6X12 that my wife pulled from Salt Lake City to Phoenix to Palm Coast FL. She thinks she had about 1500 pounds loaded. No trailer brakes.
Slow going and less than 18mpg with the 2.5D
Old June 8th, 2013, 06:42 AM
globallandrovers
Julian Kotting
a pic of my hot air balloon (3.5ton)trailer towing with defender td5, and some others i found.
Name:	Saint Albans-20130510-01082.jpg
ID:	74006   Click image for larger version
ID:	74008   Click image for larger version
Old June 8th, 2013, 06:51 AM
As a Teenager in England, oddest thing I ever towed were winch cables used to launch gliders behind 109 during the time Biggin Hill was used by an RAF gliding school. 3-4000 feet of cable times two.....
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
Need a D90 SME - GVWR, GCWR, Towing capabilities... snosrfr Defender Technical Discussions 9 August 20th, 2012 01:25 AM
towing with a D-90 gofins Defender Technical Discussions 9 October 20th, 2005 11:53 AM
