Defender Suspension - Page 2 - Defender Source
Old August 28th, 2014, 08:03 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Originally Posted by Z.G View Post
It'll sound biased, but I really recommend Fox.... I run them on both of my Discos.
Fox/bilstein/kings all great shocks.... Better than the others for sure but it all depends how far you want to go...too bad fox doesn't make a short body IMHO OME makes a great product that is perfect for 95% of people out there... You can get a OME spring/bilstein kit if you want slightly better shocks from some outfit out there (RN)... Most people don't need the performance at better than that level...
Old August 28th, 2014, 09:23 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Old Man Emu
concur. I had that on my Jeep TJ and my Disco 1. Great suspension.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old August 28th, 2014, 10:45 PM
I run OME springs and billy shocks on my trucks.
Old August 28th, 2014, 11:06 PM
KKilo23's Avatar
KKilo23
Kenny
HD OME Front MD OME Rear with Bilsteins... very happy with it.
Old August 29th, 2014, 12:02 AM
C391HAT's Avatar
C391HAT
Zach
86 110
Found on the interwebs: http://forums.lr4x4.com/index.php?sh...12#entry437086
The best way to measure your lift is to measure your spring heights with the
vehicle parked on level ground,measure from top to bottom of the rear of the
front spring,and the same for the rear spring,with quality springs you will
find that the drivers side is always slightly taller
STD 90/110 FRONT SPRING measures 260mm +/- 5 mm
The REAR SPRING should be around 300 mm +/- 10mm
Old August 29th, 2014, 02:55 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Stay away from TF shocks, especially the big bore = junk.
I'm installing TF HD 2" springs and Fox 2.0 IFP shocks I'm my latest build. This setup has worked well for me and I like the ride.
Semper Fi!
Old August 29th, 2014, 11:17 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Why? Personal experience?
Old August 29th, 2014, 11:54 AM
87 D110 (Ruby)
Jon may be the only person I know who has gone through 5 suspensions in as many years - could be more
Old August 29th, 2014, 12:20 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
What, Jonathan going through suspensions?
Old August 29th, 2014, 12:54 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
My 110 CSW (with external cage, similar to a NAS110) and HD chassis, I have standard factory springs (110 HD/130 rear dual springs) and standard fronts (although could possibly do with something slightly longer, an inch or so), and OME dampers.
Thing handles a dream. Enough clearance to fit 255/85's if I want, and with sway bars front & rear, it really does "chuck around" well, no problems at all.
Old August 29th, 2014, 06:33 PM
87 D110 (Ruby)
So funny thing Clay and I met up and looking at both vehicles... My front with the spare on the hood and a bigger bumper, no winch yet, was 2.5-3" lower than Clays original BUT the rear measurements were the same.
So upon looking we were OMG!!!!! - Look at how short my front springs are!!! Same number of loops (9) but mine were 2-3" shorter than his on measurement.
Yes mine is nose down bit at least now I know it is because of the actual springs fitted.
Pics for viewing pleasure.
John - I will post up the measurements later for you mate.
ID:	101809   Click image for larger version
Old August 29th, 2014, 09:06 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yes. The big bores lasted less than 6 mos, maybe 500 miles. They couldn't keep up with me off road. The worst shock I've ever run. ------ Follow up post added August 30th, 2014 10:06 AM ------
Sigh. Sad, and true. ------ Follow up post added August 30th, 2014 10:09 AM ------
That's a priceless pic. Those were custom springs Justin had made for me in the UK. They lasted a mile on the trail and were immediately taken back out.
Semper Fi!
Old August 29th, 2014, 11:32 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Originally Posted by diesel_jim View Post
My 110 CSW (with external cage, similar to a NAS110) and HD chassis, I have standard factory springs (110 HD/130 rear dual springs) and standard fronts (although could possibly do with something slightly longer, an inch or so), and OME dampers. Thing handles a dream. Enough clearance to fit 255/85's if I want, and with sway bars front & rear, it really does "chuck around" well, no problems at all.
What's a HD chassis... Heard of them on wolfs but never on csw's.....
I used to rub my 255/85r16 with a 1.5-2" lift at full articulation but I had my sway bars removed.... That may be the difference...
Old August 30th, 2014, 12:01 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I Built my 110 and used a heavy duty military chassis as a Base.
Old August 30th, 2014, 12:06 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Sweet... Great idea
Old August 30th, 2014, 12:14 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
It came off of a Northern Ireland armoured 110 (well, didn't "come off" as it was never used), once I got it galv'd it weighed 273kg. but has strengthening pieces welded all over it.
When doing a cross axle twister, the bodywork doesn't creak like my old 110 did!!
Old August 30th, 2014, 12:21 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
It came off of a Northern Ireland armoured 110 (well, didn't "come off" as it was never used), once I got it galv'd it weighed 273kg. but has strengthening pieces welded all over it. When doing a cross axle twister, the bodywork doesn't creak like my old 110 did!!
You wouldn't have a extra one of those for a 90 do you lol
Old August 30th, 2014, 02:07 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
So funny thing Clay and I met up and looking at both vehicles... My front with the spare on the hood and a bigger bumper, no winch yet, was 2.5-3" lower than Clays original BUT the rear measurements were the same. So upon looking we were OMG!!!!! - Look at how short my front springs are!!! Same number of loops (9) but mine were 2-3" shorter than his on measurement. Yes mine is nose down bit at least now I know it is because of the actual springs fitted. Pics for viewing pleasure. John - I will post up the measurements later for you mate.
Sorry if you already mentioned this but are you both running the same drivetrain?
Old August 30th, 2014, 08:06 AM
Jonesy I forgot to mention that if you are unsure what spring rate to get, I have a set if scales here that allow you to measure the weight at each corner. Might help establish what you need.
Originally Posted by pendy
I'm here for the D's
Old August 30th, 2014, 08:23 AM
the rover shop
shayne young
So funny thing Clay and I met up ........"
So upon looking we were OMG!!!!! - Look at how short my front springs are!!! Same number of loops (9) but mine were 2-3" shorter than his .
Jonesy... No self respecting Aussie should be comparing ANYTHING with his buddy's and dancing around going O...M...G.. Mine is so much shorter than yours... You're a bloody australian man.. Stone the crows and keep quiet about how short your "spring" is...
Defender 110 suspension kit for sale Oliver Whiting For Sale - Parts 0 April 27th, 2014 08:04 PM
Used, complete RoverTyme (RTE), QT and Fox 2.0 Defender suspension kit! - For Sale HeloBubba For Sale - Parts 5 April 1st, 2013 06:38 AM
Defender 110 Suspension Options Rugbier Defender Technical Discussions 18 March 17th, 2010 07:39 AM
Defender rear suspension parts cgalpin Wanted 18 September 22nd, 2009 08:59 AM
Defender suspension advice defendercr Defender Technical Discussions 7 July 16th, 2009 07:01 PM
» Defender Registry
"HAL"
redrange
Slowgo
Danimal
Add your Defender
