Defender Steel Wheels - Defender Source
Old October 1st, 2006, 12:09 PM
ex_mod_110
Troy MacQuarrie
I just removed the steel wheels from the 110 to clean some of the layers of paint off before I fit new tires. When the tires came off I seen that they had tubes in them. Upon more careful inspection of the wheels I noticed that one wheel has the center section welded to the outer ring. The other 3 wheels have a large rivet attaching the centre to the outer ring. My question is, will these wheels hold air or will they need a tube. I hope everyone can understand what i mean from my explanation.
Troy
Old October 2nd, 2006, 08:02 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Sounds like you have 2 differnt style rims on your truck
Legend in My Own Mind.
Old October 2nd, 2006, 09:46 AM
ex_mod_110
Troy MacQuarrie
They are actually identical in every way with the exception 1 is welded the others are riveted.
Old October 2nd, 2006, 10:59 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
My NAS D110 had steel wheels and came with tubes. I ditched the tubes when I put on new tires. No leaks!
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old October 2nd, 2006, 11:19 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Your probably fine but just for insurance, I would weld the other three and lay down some silicone. Might as well while you have them off.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 3rd, 2006, 02:50 AM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Could this be a quality control issue?
Old October 3rd, 2006, 05:05 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Check the part numbers on the weels. they will be stamped on.
You can run tubless tires on tubed wheels... they will take a special valve stem... Which IMO is better than normal ones, last longer and gives you the future option of putting tubes in if you ned to.
that said the ones with the rivits will probably not hold air unless they are sealed... at least that is my understanding. Do what buck said and run a bead around the seam and rivits.
steel wheels, wheel, wheels
5 33x12.5x 15s BFG MTs on trek outfitters steel wheels draaronr For Sale - Parts 4 June 9th, 2005 09:06 PM
6 Steel Wheels 15x7 arbik For Sale - Parts 2 April 7th, 2005 11:41 PM
110 steel wheels and tires artm For Sale - Parts 3 January 21st, 2005 09:06 PM
Steel wheels! TwisteD90 Wanted 0 November 2nd, 2004 02:11 PM
Are you using stock alloys or steel wheels? dave_lucas Misc. Chit-Chat 3 October 3rd, 2004 03:56 AM
