Defender Fender Side Table Project - Defender Source
Old April 6th, 2015, 10:45 AM
asaldworth's Avatar
asaldworth
Alex
1995 NAS D90 ST
As promised, here's a brief write-up and pictures of my end table project.
Supplies
Defender Fender (purchased off of Craigslist)
Wing top vent (provided by Jason @nathanwind)
Klean-strip Aircraft Paint Remover
Rubber gloves
Chemical resistant paint brush
Plastic paint scraper
Drop Cloth
Dremel w/ metal cutting bit
Drill w/ drill bits
Steel wool (00 and 000)
Simple Green
An assortment of black pipe and flanges
Process
Strip the paint. Don’t bother with paint strippers from Lowes/Home Depot, go straight for the professional grade stuff. I went with Klean-strip Aircraft Paint Remover from Pepboys. After leaving it sit for 15-20 minutes, the paint flaked off. There were a few areas that required a 2nd coat or a little elbow grease with the paint scraper, but it was much easier than I thought. I was left with matte gray aluminum. I then took 00 Steel wool and used Simple Green as a cleaner/lubricant, making sure to go in a linear direction. Once I could see the shiny aluminum come through, I went over everything with 00 again, but with less pressure, and then followed that up with 000. Once the Aluminum was nice and shiny, I cut the fender to size and then made a base with ½” black pipe and flanges that I purchased from Home Depot.
ID:	117752   Click image for larger version
ID:	117754   Click image for larger version
ID:	117756   Click image for larger version
ID:	117758   Click image for larger version
Old April 6th, 2015, 11:36 AM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Man, if married, I love your wife. Next I can see using right and left wings as armrest for bench seating love chair!
Old April 6th, 2015, 12:02 PM
Came out good Alex! Glad the vent came in handy. How stable is it with the 3-legs (assuming there is just 1 in the rear)?
Old April 6th, 2015, 12:18 PM
I think they call the Land Rover Sofa a Range Rover.
Old April 6th, 2015, 12:24 PM
Hardtimes's Avatar
Hardtimes
Russell Newhall
110dc, 110sw, 97 nas90 LE
I really like it. THanks for sharing
Old April 6th, 2015, 02:06 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Are you putting lights in it?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old April 6th, 2015, 02:22 PM
asaldworth's Avatar
asaldworth
Alex
1995 NAS D90 ST
I’m not married, but I receive a lot of ‘input’ when it comes to the decor.
Yes, it's a tri-pod. I used flanges (see picture attached) as the feet, which made it really sturdy. I wouldn’t stand on it, but it’ll definitely support a few glasses / magazines without a problem. Thanks again for the vent.
My plan was to get a Headlamp Finisher (to cover up the huge hole someone drilled under the light) and at least add the running lights, but the look without the lights is starting to grow on me. Thoughts?
Old April 6th, 2015, 02:57 PM
At work he uses this.
Old April 6th, 2015, 09:25 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Well...you always have a spare if needed.....nice job.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Water Purification System, Springs, Shocks, Front runner side table. thinairathlete For Sale - Parts 1 November 21st, 2014 12:05 AM
rei camp table full size family.. the rover shop The Flea Market 2 August 31st, 2012 03:03 PM
rear door folding table Overlander Smaller Projects 9 March 27th, 2009 01:20 AM
safari door folding table Overlander Defender Technical Discussions 9 December 12th, 2006 10:50 PM
Rear door table! TwisteD90 Defender Technical Discussions 10 April 5th, 2004 11:43 PM
» Defender Registry
RAF
Realm
Rupert
REDrum
Add your Defender
