Defender 90 door panels - Page 2 - Defender Source
Old February 21st, 2008, 12:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks for the info Mike
Is there any reason I wouldn't want to update my 94? What do you do with 94 trucks that come in and need panels?
Is it an easy job to change the retainers that keep the doors open
Old February 21st, 2008, 12:17 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Originality would be about the only reason.
To date we have just replaced damaged panels with correct replacements, but we ran out of stock of replacements a short time ago... so on the next truck??.... who knows.
No it isn't an easy swap. Its kinda a PITA.
The last truck we did we didn't have any good used panels, nor could we find correct replacements so we fixed the panels and then Rhino-Lined them. Not the best option, but worked for that project.
http://www.eastcoastrover.com/198.html
Email:
Old February 21st, 2008, 12:19 PM
Has anyone considered trying to use early 90/100 panels? I know RDS had one side in stock? EDIT: george also has 1994 panels in stock $300 per:
http://www.roversdownsouth.com/body.htm
Old February 21st, 2008, 12:23 PM
ECR's Avatar
ECR
You can't get to the door top studs on those unless you take them apart and they have a different door latch location than the NAS if I recall from my old '84 110.
Email:
Old February 21st, 2008, 12:35 PM
Backstay
John Hilton
1994 D90
94 door panels
Just to add to the door panel frenzy....I am having the 94 door panels duplicated. My initial order is 50 pairs. I will post pics when ready.
Old February 21st, 2008, 12:37 PM
ECR's Avatar
ECR
The "original" 94 versions (black padded style) or something else??
Email:
Old February 21st, 2008, 12:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
The biggest issue I have with my panels is the screws ripping out. Are there others things that wear out? Any way to fix the screw holes?
Old February 21st, 2008, 07:42 PM
themaxx's Avatar
themaxx
Ade
94 ST
Someone suggested gluing a thin strip of aluminum along the screw area of the panels.
Old February 22nd, 2008, 07:30 PM
Backstay
John Hilton
1994 D90
Not the "original" vinyl covered plastic, but .150" automotive haircell which will give more strength particularly for mounting screws. Overall it will be about the same thickness as the original laminated material.
Old February 22nd, 2008, 07:36 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will they be black?
Old February 22nd, 2008, 08:04 PM
Backstay
John Hilton
1994 D90
Yes, black.
Old February 22nd, 2008, 09:05 PM
bjf's Avatar
bjf
barry f
94 ST #395
Cool. Look forward to seeing them
Old March 3rd, 2008, 08:01 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Man, we will have lots of options... I have the 94 setup on my truck... dammit...
Mike, I have the brackets for the bulkhead and the arms that go to the door for the 95-97 doors. what about the actual door bracket? Is that a bolt on Idem or a welded on tab like on the series IIa doors?
will the 97 style door panels work ont he 94 style doors? Or is there interference?
Legend in My Own Mind.
Old March 3rd, 2008, 09:35 AM
Its a little welded-on bit, basically a square "c" - the door check goes in the middle and a clevis pin drops in from the top. I dont think the 97's will fit - there isnt the "channel" above the speaker housing for the prop rod to slide.
Old March 3rd, 2008, 06:29 PM
Backstay
John Hilton
1994 D90
Just to keep you up to date on the 94 door panels. The tooling for the one side is almost done and I should have a prototype from the factory in a few weeks. Once that is perfect, we'll get the other side done. Probably a good 60-90 days before everything is ready. Tooling picture attached.
Name:	door panel tooling.jpg
Old March 3rd, 2008, 06:54 PM
themaxx's Avatar
themaxx
Ade
94 ST
What other improvements are you making on these? Rough idea on price?
Old March 3rd, 2008, 08:18 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Lookin' great John!!!
Maybe you could maybe add a bit wider lip on top to facilitate resting ones arm on the window sill when its closed?.. I'm not sure how it would be, or how much you'd need.. my truck is not here at the moment, but just thinking out loud for possible improvements..
anyone?
regardless, looks good so far
keep it up!!
~Steve
Old March 4th, 2008, 08:01 PM
Backstay
John Hilton
1994 D90
Everyone seems to want them as orginal so we're only improving the mounting. Price should be just under $400 for the pair.
Old March 4th, 2008, 09:19 PM
hartman
Edward Hartman
1997 D-90
Sounds Good, I'll be in for a set.
Old June 13th, 2008, 12:34 PM
Backstay
John Hilton
1994 D90
Latest picture....
The door panels are coming along. A lot more work than initially expected to make them right. Will still be a little while but we're getting there!
90, defender 90, door, panels
F/S 1995 Defender 90 ToddR For Sale - Vehicles 9 September 19th, 2016 06:09 PM
Electrical Issues & the best repair manuals for a 1995 D90 agavelvr Defender Technical Discussions 18 August 23rd, 2011 12:54 PM
1994 Defender 90 - Hardtop and A/C silver_defender For Sale - Vehicles 4 August 14th, 2009 03:31 PM
1995 Defender 90 ST 2468 with 43000 miles EXCELLENT CONDITION funrover For Sale - Vehicles 1 September 25th, 2008 08:52 PM
94 defender 90 w/ 27k miles ebanks For Sale - Vehicles 5 September 8th, 2004 01:05 PM
