Death wobble saga - Defender Source
Old February 12th, 2005, 01:15 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Death wobble saga
Well the hunt continues. I have had off and on front end wobbles at high and low speeds for awhile now. Sometimes it will be months between episodes but when it happens it is violent. I know it is always the last thing you change but here is what I have done so far and what I plan to do in the next week or so. I have changed all the suspension to HD OME and new steering dampner. All new steering ball joints and tie rod (it was bent ). All new suspension bushings with OEM rubber. I took it for a drive yesterday and within one block at 20 miles and hour I hit a bump and it sent the truck into a siezure. Wheel bearings have been bought and will be put in next week along with adjusting the preload if need be. I have a feeling it is the preload or wheels out of ballance. That would be just great if it where the two cheapest and easiest fixes Obviously I am a dumbass for not starting there first but I figured all the other stuff needed replacing anyway at least that is what I tell my wife I think that covers all of it. If anyone can think of another cause please let me know.
Kevin
Old February 12th, 2005, 01:23 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
engine mounts maybe?
Old February 12th, 2005, 04:41 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
How old is your ride?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 12th, 2005, 05:12 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
First thing I thought of was steering dampner, but you said that's been changed already. Regular shocks too?
Could also be really wonky front wheel alignment, the joints for the steering knuckle, I'd also inspect the rag joint and steering box.
Not much left to check though, really.
-Hans
Oh, here's another I just thought of. Is your transfer case locked in position maybe? how is the condition of the front differential?
-Hans
My oil line fix
My 100k stopped odometer fix
bjenk
Brian Jenkinson
1994 D90
Your going to respond to this...and I am prepared...I bought my 90 in October (i mean my wife bought my 90). I went to AZ to pick it up and so happen to find someone in New Mexico selling an ARB bumper. So, I picked it up on the way home. Once home I was so excited to put the bumper on I took the skid plate off and mounted the bumper. I then took the wife for a ride. I did not put the skid plate back on because I had to take a notch out to fit with the ARB. Nor did I put any bolts back on, including the three bolts that secure the steering control arm. I drove it for about three weeks on and off (no skid plate or bolts). We took it 4wheel'n, but on the way back to denver I noticed a lot of play in the steering. I stopped and looked underneath...nothing out of wack or place...We continued on to Denver via I-70 I was going about 70 mph when...Oh shnikes...The thing started to shimmy everywhere. Lucky I was able to slow down and get it undercontrol. Upon pulling over and taking a serious look I noticed the IDGIT had left out some important bolts. I confessed to my wife that it was my stupid mistake and not a lemon of a vehicle!
Steering stabilizer... Death Wobble.. TDI Guy Defender Technical Discussions 13 September 15th, 2008 12:27 PM
Non D90 tech question... Wobble while braking. jabber Defender Technical Discussions 5 August 30th, 2005 09:22 PM
The continuing rat saga, evaporative canister edition. jcasteel Defender Technical Discussions 3 April 12th, 2005 02:59 PM
Death of a T-Case flippedrover Defender Technical Discussions 14 May 21st, 2004 07:28 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
