D110 question - Defender Source
Old September 24th, 2009, 12:15 PM
disco dog's Avatar
disco dog
Tracy Dwyer
2002 D110 TD5
D110 question
Hey guys, I could use some help. My D110 (2002 TD5) appears that the right rear wheel has gear oil on it from my last drive, last week. I would assume that the axle seal has gone bad and needs to be replaced. This truck is at my home in Cost Rica, and I don't really want my local shop touching this truck if I can help it, so my question is this, is this something that I can fix myself with normal tools, or will it require something special, or is it worst than I think? I live 8hrs away from a real LandRover shop, and would not drive it that far if I can help it. Back in the states for now ( and for the MAR), but need to fix . Any help would be appreciated.
Old September 24th, 2009, 12:26 PM
You should be able to take care of this yourself. The only tool you may need is a Hub Nut socket. I think it is 2 1/16. Some say you could use a large socket, but I have not tried it yet. I think they are $15-$20 from AB or RN.
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
you can fix that yourself. seems to be the inner axle oil seal. jack the truck up, remove the tire, and take the caliper off with a 12point 13mm socket (I think it is 13mm but i might be wrong). Unbolt the axle and slide it out. then get a 52mm socket or 2 1/16" socket or hub nut removal tool and take hub off. then you can access the inner oil seal.
put it all back together and you should be fine. remember to tighten the hub down nice but not too tight.
only special tools you need is a 12point 13mm and a hub nut socket tool
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
110, d110
D110 Question disco dog Misc. Chit-Chat 12 February 15th, 2009 06:48 AM
NAS D110 Headliner Question Stmpede Defender Technical Discussions 8 November 6th, 2008 12:15 PM
New D110 owner question BEIS Defender Technical Discussions 8 October 29th, 2008 09:52 PM
1984 D110 OEM wheels question ctrover Defender Technical Discussions 4 April 30th, 2008 02:21 PM
Question about 2" lift on NAS D110 Stmpede Defender Technical Discussions 10 April 3rd, 2007 06:12 PM
