D1 ignition switch problem - Defender Source
Old July 2nd, 2013, 03:40 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
I have a '97 Discovery. Last night my daughter had a major problem removing the key from the ignition switch.
After many tries and much fiddling it finally came out. We've tried it 20 times since with no problems.
When the key was stuck, it would not rotate to the last position where the key comes out. It felt like there is some mechanical interlink preventing that last movement.
What do I look for? How do I ensure future operation?
Old July 2nd, 2013, 08:11 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Mike,
I'm dating myself 2 rovers ago but I had this same issue. I want to say it was connected to the vehicle not sensing it was in park.
Is this an auto or manual disco?
Old July 2nd, 2013, 08:22 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Automatic. It has 130,000 miles.
Originally Posted by josh-man View Post
Mike,
Old July 2nd, 2013, 09:07 AM
rovertrader's Avatar
rovertrader
Dale
First thing to try is WD40 into the key receptacle- then insert key, and rotate several times. Usually buys you a couple years....
Old July 2nd, 2013, 09:47 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I just had the same issue on my 96. I eventually broke the key off in the ignition trying to work it out. I ended up taking the thing apart and removed parts of the tumbler . Haven't had a problem since.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old July 2nd, 2013, 09:59 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I would try graphite before WD40. Graphite works wonders in locks.
switch
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
Ignition Problem Dfndr90 Defender Technical Discussions 1 November 21st, 2004 08:26 PM
