Cummins 4bt in a 110 any thoughts? - Defender Source
Old May 6th, 2011, 01:11 PM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
Hey guys, about to get back from Afghanistan. Looking to maybe swap the engine in my '83 110. To give some back ground, it's a soft top 110 totally done up by safari rover in Orlando. Everything was restored a couple years ago. However, I kept the same old old old engine. Thinking about doing a 4bt swap in it. To give some info about the truck: it currently is an automatic (has the '97 d90 automatic tranny in it). Is it possible (or even recommended) to drop a 4bt in a 110, then marry it up to a '97 automatic tranny? Bottom line, I'm looking to replace the engine with a more dependable one (keeping it automatic and hopefully diesel). Any thoughts? Thanks guys.
-Ryan
Old May 6th, 2011, 02:04 PM
Rugbier's Avatar
Rugbier
Gustavo
Ryan,
Contact Dan Rao ( Slorocco ) here, he has that on a 109, he could give you ample guidance
NO SIGNATURE
Old May 6th, 2011, 02:29 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
There is also someone doing a kit to put a MB 300td in a defender
Old May 6th, 2011, 03:36 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
It would be infinitely easier and cheaper in the long run to use a rover diesel instead, or a 2.8 international.
Old May 6th, 2011, 04:58 PM
Just build up a 14CUX EFI motor with a 4.6 short block.
Old May 7th, 2011, 01:02 AM
rovertrader's Avatar
rovertrader
Dale
drive a 4BT first- it is the only thing louder than an old Defender. I agree with the MB conversion Robt Davis is nearing completion for a package.
Old May 7th, 2011, 01:16 AM
grnrvrs's Avatar
grnrvrs
Paul
88
An Isuzu 4BD1T is very good option, but a bit $$ to do nicely.
Old May 7th, 2011, 09:59 AM
Roving Beetle
Doug
4BT is a very loud annoyingly rattly motor in a vehicle like a D90. Not enough sound proofing and distance between you and the motor - and I LOVE diesels....
The 4BD1T is a smoother quieter motor for sure, the MB even more so, and a VW TDI more so again.
If you're stuck on the 4BT for the cheap factor keep in mind the motor itself IS the cheap easy part no matter what you go with!
The ZF will not like the diesel power band, too much low torque before it can build line pressure. Talk with Ashcroft or another good ZF builder as you WILL need to beef it up first. That said you'll be cheaper and easier in the long run to sell the ZF, buy an adapter from Marks (or build one yourself) and mate the LT230 to a 4L80.
--------> Or use a Rover 200-300-TD5... way easier for sure.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old May 7th, 2011, 07:45 PM
Hot rod a 4.6 or a stock Td5, having had a sip of the Td5 coolaid I want an entire pitcher.
110, ht
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
110 Died - Your Thoughts? 3rovers Defender Technical Discussions 2 February 10th, 2008 12:48 AM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
