cost of parts to convert manual to automatic transmission - Defender Source
Old September 14th, 2006, 12:21 PM
mgrgpg
Mark
1989 D110
I am looking at converting my 94 to an automatic transmission. For those that have done it, what is the ball park price for the needed components.
Mark
Old September 14th, 2006, 10:39 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Depends on parts, new or used and what you want to do for a console/shifter. The least expensive way is to get a used tranny with all parts from the crank back and run a tall shifter up thru your 5 speed boot. This can be done for under a grand. It goes up from there, a good rebuilt unit from Erikkson will cost you 1300-1500 alone. If you want to go stock and locate a 97 console you will spend almost as much on that as a good used ZF tranny.
I got a good used tranny/parts for $750 and scored a used 97 console/shifter for $200, but that was years ago.
Tis
Old September 15th, 2006, 08:35 AM
mgrgpg
Mark
1989 D110
Thanks - I am looking to switch the center console, etc - just like a factory automatic.
Mark
Old September 15th, 2006, 09:07 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Has anyone seen a disco I or II console used in a d-90? I know, somewhat of a hack, but it might solve the problem of finding a '97 console.
Old September 15th, 2006, 09:53 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
George has them for like 600 bucks. A company in the UK is making them.
EwS
Old September 15th, 2006, 10:30 AM
Chaucer
Will
93 110 | 97 90
Ashcroft is selling the console. This one looks like it's around $610 before shipping. It does appear to be fully assembled with regard to the console lid, lock, hinge, etc. RDS just gives you the parts. I suppose it depends on where you want your time/money to go.
http://www.ashcrofttransmissions.co.uk/part_56.html
Old September 15th, 2006, 12:56 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
Why not sell the '94, and then buy a '97. The price it will cost to convert could very well be the difference in price of both trucks. you might even get lucky and get a better truck than the one you currently have. Plus the console and everything would be factory.
Old September 15th, 2006, 12:57 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Nice, even has the cup holders which previous aftermarket versions did not have.
Old September 15th, 2006, 01:41 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
You would also have to plumb in a transmission cooler as well and buy a new lower radiator support shroud. Or you could drill holes in the existing one. Good luck.
neil
Old September 15th, 2006, 09:15 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
I drilled holes in the existing one, but I've seen two who ran a pep boys cooler and located it in front of the rad.
manual, part, parts, transmission
Parts Manual Kimos Defender Technical Discussions 38 December 9th, 2004 06:09 PM
manual transmission needed ember Wanted 0 August 31st, 2004 11:50 PM
How difficult is it to convert auto trans to manual in a D90? jaherring Defender Technical Discussions 14 June 17th, 2004 02:05 PM
convert to an automatic transmission Campbell Defender Technical Discussions 9 March 23rd, 2004 03:01 PM
Automatic transmission lobster Defender Technical Discussions 2 December 31st, 2003 07:25 AM
