correct my thinking - Defender Source
Old March 25th, 2007, 09:23 PM
huck1974's Avatar
huck1974
shane cates
94 d90
correct my thinking
did the 2" lift but haven't decided on a shock setup. Why would I lower the rear shock mounts when a longer shock would work just as well? I guess I want the shock setup that does not bottom out but allows the most travel. I need guidance on this and front shock relocation advantages. Thanks.
Old March 25th, 2007, 09:46 PM
themaxx's Avatar
themaxx
Ade
94 ST
I hope this helps...
Originally Posted by 1of40
I wanted greater articulation of my rear axle and advice I received was to lower my shock mounts and replace my rear shocks with extended length ones from OME. Come to find out the advice was not exactly correct. After lowering my mounts the extended length shocks were a little too long and all i needed to do is either or, but not both. Sorry long story.
Old March 25th, 2007, 10:09 PM
huck1974's Avatar
huck1974
shane cates
94 d90
kinda my thinking, but some of you guys know how to get the most. I don't want to try to reinvent the wheel with my checkbook.
Old March 26th, 2007, 01:20 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
Either/ or. Just keep the stock shock mounts and get a longer travel shock.
Side step install - do it look correct? paulb Defender Technical Discussions 10 January 25th, 2008 02:53 PM
Newb thinking about buying D90-HELP Todds112 Defender Technical Discussions 21 October 26th, 2005 09:26 PM
What is this guy thinking? boshea Misc. Chit-Chat 12 October 11th, 2005 03:18 PM
Odometer/speedo correct? sherpamike Defender Technical Discussions 2 October 15th, 2003 08:52 AM
Thinking about 315 75 r16 MTRs evilfij Defender Technical Discussions 3 October 15th, 2003 04:19 AM
