Coolant Pressure Tester Adapter for RRC/DI - Defender Source
Old June 27th, 2016, 10:01 AM
boyrover
Sean
1996 Discovery
So after researching this for awhile and finding conflicting information I was finally able to pin this down. I bought Stant Part # 12023 and have field tested it on a 1994 RRC and a 1995 and 1998 Di and it fits perfectly and holds pressure.. Interestingly it shows online that it does not fit a 1995 model but it shows it will fit a 1994 model. I figured that the tanks were the same 1994 to 1995 and that was the same black plastic tank used on the DI. As far as I can tell, it will work on all Land Rover vehicles with the black plastic tank. I bought mine at Amazon, they are available elsewhere on the net as well. The link below includes a picture of the adapter. Hopefully I'm not telling you guys what you already know. For anyone trying to figure this out, hopefully this helps.
https://www.amazon.com/Stant-12023-T...=sr_1_1&sr=8-1
cd, coolant
what's a good coolant pressure tester? Overlander Defender Technical Discussions 10 December 19th, 2014 04:21 PM
Coolant system pressure "vs" gagging at high rotation fmrodrigues Defender Technical Discussions 5 May 21st, 2014 10:30 AM
Homemade 200Tdi VDO Coolant temp sender adapter DannyboyUpstate Defender Technical Discussions 1 January 11th, 2014 05:20 PM
Oil Pressure Switch Adapter Firemanshort Defender Technical Discussions 1 June 7th, 2009 01:31 PM
VDO Oil pressure adapter Hoosier Defender Technical Discussions 7 December 10th, 2007 01:54 PM
