Convert pdf to jpeg - Defender Source
Old January 26th, 2011, 11:01 AM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Convert pdf to jpeg
I've tried a couple of freeware programs but no luck. I need to convert a pdf file to a jpeg to make a banner for a little league team we sponsor. Anyone out there have more knowledge on this or can do it for me, I can upload the file. Greatly appreciated
This is where I'm supposed to write something witty and funny; or something.
Old January 26th, 2011, 11:06 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
That's kind of a bizzare conversion. Do you want the entire contents of the PDF, or just a section of it?
If you have a Mac it's a 10 second process. Not sure about windows.
Old January 26th, 2011, 11:10 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Download and install "Gimp" (free). Load the PDF. Save as JPG. Also does graphic editing.
Old January 26th, 2011, 11:24 AM
or just capture the screen shot you want using print screen and dump to your program of choice.
Old January 26th, 2011, 11:27 AM
x2, but sometimes the copy is a little blurry.
Old January 26th, 2011, 11:38 AM
JBOD77
Jonathan
it's a company logo that we have used to print a banner or poster or etc. The marketing firm for this particular little league team wants only jpeg (understandable). they can then use that to print the banner for the outfield wall. They marketing firm that did the logo for us sent the file in pdf form. I'll try the Gimp software. don't think the screen-shot is gonna be clear enough to do what i need done.
Old January 26th, 2011, 11:51 AM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Jonathan, despite your avatar, here's my $0.02 of advise.
Double check with that marketing firm, because to me, it's not understandable that they would want a jpg. Taking a jpg logo and blowing it up for a large banner is asking for problems. Any jpg you can create based on a PDF is never going to have the scalability to be made into a large banner. You're quite probably going to have pixelization and/or loss of resolution.
What you want is an EPS of the logo. An EPS is usually generated from Adobe Illustrator (or Photoshop equivalent) and is a "Vector" graphic (look it up on Google)
A vector graphic is scalable, meaning that regardless if the logo is 6" across or 6' across, it will have the same resolution. Any company that's had a logo created professionally should have an EPS version.
Jerod
Old January 26th, 2011, 11:59 AM
JBOD77
Jonathan
jerod, inspite or your inspite of my avatar i appreciate the info. scalability of the jpeg was my initial concern but they are going to run a proof so i think i'm fairly safe there. I'm gonna see if they can use the an .eps. I use the term marketing firm loosely as i believe it is one of the dads from the team but we'll see what happens. thanks for the info!
Old January 26th, 2011, 12:08 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Jonathan,
Despite your disposition of my despising your avatar....
Here is an example:
I took a PDF of a client's logo, turned it into a JPG (very simple on a Mac) and blew it up 500%
Then I took an EPS of the same logo (sort of, different color combo) and blew it up 500%
Click the attached pictures below to see the difference. You really should find an EPS if you want to make sure the banner look right:
Name:	jpg blow up.jpg
ID:	35185   Click image for larger version
Name:	eps blow up.jpg
Old January 26th, 2011, 12:10 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Send me the pdf and I will convert to jpg.
If you can get vector based artwork it would be better quality output.
I will pm you my email to send to.
Gery
Old January 26th, 2011, 05:47 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
i work for a commercial printer and I too would rather have the pdf to size then a jpg- unless the jpg is 300 dpi to size and then its going to most likely be a larger file then the jpg - my guess is the banner guy you are using has a old workflow that only takes jpg - but even if thats true he should be able to open your pdf in photoshop and go from there
if you want send me the dimensions and what you want to pay and I can see if we can print it and mail it to you for the same price
Jay
Old January 26th, 2011, 06:01 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Good advice above.
However there's always an Open Source solution: http://www.imagemagick.org/script/index.php
service manual on pdf or cd? geneseemtn Wanted 3 November 22nd, 2005 03:32 PM
Full adventure rack for a 94 D90 Convert Bluedog Wanted 1 July 1st, 2004 08:44 AM
D90 parts manual in PDF, anyone??? artm Defender Technical Discussions 1 May 7th, 2004 10:51 PM
convert to an automatic transmission Campbell Defender Technical Discussions 9 March 23rd, 2004 03:01 PM
How to make my jpeg into a thumbnail? Chris Cox Support & Suggestions 6 October 2nd, 2003 07:18 PM
