Clutch master and slave - Defender Source
Old January 30th, 2010, 08:02 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Everyone scared me pretty good about the PITA the job was. One and a half hours later=done. Piece of cake. No more pee on my left foot.
And hay
And I love you too
Old January 31st, 2010, 03:27 AM
If your fittings come apart well, then you're in the clear. Otherwise, you're in there with no clearance trying to get the things apart. If this was too easy and you want a PITA, replace your heater core next weekend!
Old January 31st, 2010, 08:45 AM
huck1974's Avatar
huck1974
shane cates
94 d90
I'm sure that I will get to try that one eventually
And hay
And I love you too
Old January 31st, 2010, 09:26 AM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
Huck- I have peepee on my left foot; just found my master is leaking and need to replace. Did you replace the slave just as a precautionary measure while you were doing the master- or was it shot too?
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old January 31st, 2010, 10:36 AM
huck1974's Avatar
huck1974
shane cates
94 d90
I replaced them both even though the master was the only problem. Contrary to what some say, I found no need to undo the brake lines. I just kinda pushed things out of the way the best I could. I didn't bench bleed either. That probably would have saved me ten minutes of bleeding.
And hay
And I love you too
Old February 2nd, 2010, 12:22 AM
jaygoss's Avatar
jaygoss
Jay Goss
thanks Shane- I'll be doing the same this weekend. Will try it without disconnecting brake lines.
Old February 2nd, 2010, 10:07 AM
huck1974's Avatar
huck1974
shane cates
94 d90
Youll need a buddy inside the truck to align the pedal to the hole while you pull and twist from above. Be careful when bending the brake lines out of the was as to not break them. Remove the pedal cover. Remove the 13mm bolts to the brake master so you try to shove it out of the way a bit to create some room. Keep in mind where the adjustment is on the old master and adjust the new one accordingly. Don't tighten the nuts on the new one until it is installed in the truck and you are sure you like where they are at. I made that mistake and ended up grinding down a wrench to make it thin enough to not grab both nuts at the same time.
Good luck
And hay
And I love you too
Old February 2nd, 2010, 10:14 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Take the 2 nuts off that hold the brake master to the booster and then you can move the brake master out of the way easily and not mess with the brake lines. Gives the room needed to make the job a lot easier.
The only thing to be careful about is to get the pedal height and the clutch freeplay adjustment correct (its in the manual). The rest is fidly, but not hard. Nice job Shane.
Email:
clutch, master, slave
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Soft hose from clutch master tomaco1 Defender Technical Discussions 4 December 1st, 2009 01:07 PM
Clutch Slave cylinder bleed?? Quimbola Defender Technical Discussions 2 February 10th, 2009 11:17 PM
Clutch? I've got a real mystery here. Help! JakeW Defender Technical Discussions 7 May 22nd, 2007 11:10 PM
Clutch Master, Slave & hose sale @ BP Neil McCauley Misc. Chit-Chat 0 September 22nd, 2006 07:11 PM
» Defender Registry
Sandy
Sandy
D 90
TommyB
Add your Defender
