Check these out - Defender Source
Old October 10th, 2005, 11:56 AM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Check these out
Inland Rovers Swivals
What do you guys think? Worth it? Looks a lot easier than welding on heim jointed rear arms. Maybe not as much droop, but it looks liek it has to be better than the stock bushing.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old October 10th, 2005, 12:00 PM
hmm, intresting, price is a little high for me, and with the weldon stuff you gain clearance by removing those dam ears!
Old October 10th, 2005, 01:30 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
When I was in Las Vegas trying to get a replacement set of bushings, Bill Goodman had a set he was looking to sell. I was desperate as I had blown one of my bushings and still had a 4 hour drive back to CA. Anyway to make a long story short, I didn't get them. I didn't want to drop $300 and be a guinnie pig for R&D. Bill had a used OEM bushing he gave me for free, still using it. The are supposed to be rebuildable and they should work like a stock bushing, I guess. But for $25, I think I'll stick with stock for now. If I keep blowing bushings, I'll give it some serious thought.
Those weld on ones are supposed to negatively effect on road driving and be noisy.
Old October 11th, 2005, 11:29 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
While I like the idea I'm not sure I would use a Johnny Joint in a push pull situation, Without looking at the allpication I know that in most these types of joints the TFE or UHMW "races" that hold in the ball are only held in with a snap ring.
I'm with Mike "cut it's ears off"
Keith
Big, Red and ... aaa Red..
Old October 11th, 2005, 12:27 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I like the idea, but I'd have to take a closer look before I'd give it an opinion either way. Like Revor said, the retention method is critical for these parts.
I would like bigger pictures of everything, as well as shots of both sides, to see how it's really built
-Hans
My oil line fix
My 100k stopped odometer fix
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
