changing gear in low box - Defender Source
Old September 10th, 2007, 09:40 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Iv'e noticed while driving with others in low box that they pull away in first and change up through the gears. I do it back to front, pull away in 3rd and change down if need be. Decending a steep hill, 1st. Climbing a hill 2nd or 3rd depending on how steep and how long. I can't see the point in changing gears in low box, does no harm pulling away in 3rd its the same as 1st in high range. Am i the only one who drives this way or do others?
3rd low and BOOT IT
Old September 10th, 2007, 10:30 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I pull away on 3rd low all the time, it is good between obstacles. Normally the guys I go with are in auto gearboxes and I don't try to match their driving style, they have a tendency to go faster than I do between stuff driving along in "D" in low range. I prefer to trundle along at a steady pace and shift to a lower gear when I need to same as you.
Old September 10th, 2007, 11:27 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I do the same.
Jimmy Buffett
Old September 10th, 2007, 09:52 PM
Sure. Use whatever gear is needed. 3rd low would be a normal pull away gear.
Old September 11th, 2007, 06:04 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
That actually sounds like a much better way to drive in low. I usually start in second low, but even that's too low sometimes. Especially when wheeling with guys in auto's.
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Linkage - gear box shot ? My 1st time (pop!) paulb Defender Technical Discussions 10 January 21st, 2008 07:07 PM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
gear box jimmy salmon Defender Technical Discussions 4 June 8th, 2005 04:18 PM
