Changed fuel filter - Defender Source
Old March 12th, 2012, 04:19 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Changed fuel filter
And I'm glad I did. Some nasty stuff in Brit diesel . . .
Old March 12th, 2012, 09:28 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
I believe that is porridge.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
Old March 12th, 2012, 10:39 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I honestly think it was mostly mud. And bits of string. The Doug Crowther ATF in the filter trick worked great though.
Old March 13th, 2012, 12:56 AM
Tony, do you also have a sedimenter either in the rear wheel well or against the firewall? If so you may want to clean that out as well.
Old March 13th, 2012, 12:09 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I just changed mine again the other day too. How common is not having a sedimenter? I can't find it in any other usual locations so I think mine is sans-sedimenter.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old March 13th, 2012, 12:12 PM
Pretty common to not have one...in fact, a lot of owners/previous owners tend to pull theirs out completely. So I'd say 50/50.
fuel
Replacing Fuel Filter...Should be easy right? Antonios Defender Technical Discussions 5 January 5th, 2006 09:38 AM
Fuel Filter milli Defender Technical Discussions 3 January 21st, 2005 10:46 AM
Looking for a 300TDI Fuel filter EdHsu Defender Technical Discussions 2 September 12th, 2004 01:11 PM
