Ceiling liner? - Defender Source
Old January 27th, 2005, 10:06 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Ceiling liner?
So, I've noticed after installing a fiberglass headliner, the sound dampening of it is nil. In fact, reverberation of noise has gotten worse. Luckily, it is very easy to drop back down and make some changes.
Has anyone with an SW installed some type of very, very lightweight sound and/or vibration dampening on the roof/ceiling?
I was looking at Cascade and Dynamat , but I can't determine what they have that fits the bill. The lower body portions of my truck are lined with Extreme Dynamat, and while it works well, it's extremely heavy. So it's not going up there.
I guess a foam based, vinyl product makes the most sense. Lightweight and absorbant.
Thoughts?
Old January 27th, 2005, 10:24 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
David,
http://www.b-quiet.com/hliner.html is on order. I used the BrownBread to good effect elsewhere in the truck and am waiting for the weather to break so I can tear into the roof/doors.
EwS
EDIT look into the LComp and VComp products as well.
Old January 30th, 2005, 04:36 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
What about the Brown Bread for the roof? I am planning on doing it next month. I don't know how the weight of the Brown Bread compares with the dynamat, but I wouldn't use the b-quite Hliner on my roof. I put it under the hood, and didn't notice any difference. I like the Brown Bread because it's solid after you put it on and tap on the exterior, you can hear the difference with less vibraton.
Old January 30th, 2005, 06:44 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
You could use it up there no problem. Check the site, I think they are changing products and not producing brownbread anymore...
EwS
Spray on liner for interior WestTexasDefender Defender Technical Discussions 25 November 25th, 2008 10:11 AM
Rebuilding a v8 engine - how to fix liner problems robisonservice Defender Technical Discussions 10 August 19th, 2006 10:18 PM
Door entry guards and cardo liner rustydefender Defender Technical Discussions 15 January 8th, 2005 11:41 AM
Line X / Spray In Liner ? rcmorgan540 Misc. Chit-Chat 10 June 1st, 2004 02:49 PM
speed liner or rhino liner TDI Guy Misc. Chit-Chat 5 May 5th, 2004 09:27 PM
